Datasheet Microchip ATmega8A — Даташит
Производитель | Microchip |
Серия | ATmega8A |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 8KB ISP flash memory with read-while-write capabilities, 512B EEPROM, 1KB SRAM, 23 general purpose I/O lines, 32 general purpose working registers, three flexible timer/counters with compare modes, internal and external interrupts,serial programmable USART, a byte oriented two-wire serial interface, 6-channel 10-bit A/D converter (8-channel in TQFP and QFN/MLF packages), programmable watchdog timer with internal oscillator, SPI serial port, and five software selectable power saving modes
Купить ATmega8A на РадиоЛоцман.Цены — от 28 до 529 ₽ 59 предложений от 32 поставщиков 8- бит AVR RISC микроконтроллер (8K ISP Flash, 512 bytes EEPROM, 1K SRAM, 32x8 register, 2x8-bit/1x16-bit timer/counters, 3xPWM, 8-ch 10-bit ADC,... | |||
ATmega8A-AU Atmel | 28 ₽ | ||
ATMEGA8A-AU Microchip | от 137 ₽ | ||
Транзистор биполярный ATmega8A-PU Atmel | 374 ₽ | ||
ATMEGA8A-PU Atmel | по запросу |
ATMEGA8A-AN | ATMEGA8A-ANR | ATMEGA8A-AU | ATMEGA8A-AU-HCM | ATMEGA8A-AUR | ATMEGA8A-MN | ATMEGA8A-MNR | ATMEGA8A-MU | ATMEGA8A-MUR | ATMEGA8A-PN | ATMEGA8A-PU | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 |
Корпус | TQFP | TQFP | TQFP | TQFP | TQFP | VQFN | VQFN | VQFN | VQFN | SPDIP | SPDIP |
Parameters / Models | ATMEGA8A-AN | ATMEGA8A-ANR | ATMEGA8A-AU | ATMEGA8A-AU-HCM | ATMEGA8A-AUR | ATMEGA8A-MN | ATMEGA8A-MNR | ATMEGA8A-MU | ATMEGA8A-MUR | ATMEGA8A-PN | ATMEGA8A-PU |
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
ADC with Computation | No | No | No | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 |
High Voltage Capable | No | No | No | No | No | No | No | No | No | No | No |
I2C | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 28 | 28 |
Math Accelerator | No | No | No | No | No | No | No | No | No | No | No |
Max 16-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Max 8-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
Max PWM outputs, including complementary | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
Package Width | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 5x5x1mm | 5x5x1mm | 5x5x1mm | 5x5x1mm | .300in | .300in |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No | No | No | No |
Pin count | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Размер памяти программ, KB | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
SPI | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
SRAM, Bytes | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 | 1024 |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Zero Cross detect | No | No | No | No | No | No | No | No | No | No | No |
Серия: ATmega8A (11)
- Microcontrollers > 8-bit Microcontrollers
