Datasheet Microchip ATSAMC20N17A — Даташит
Производитель | Microchip |
Серия | ATSAMC20N17A |
The Microchip SAM C series of 5V Cortex M0+ devices is designed for industrial and commercial applications in noisy environments
Купить ATSAMC20N17A на РадиоЛоцман.Цены — от 352 до 33 190 ₽ 17 предложений от 8 поставщиков ARM® Cortex®-M0+ SAM C20 Microcontroller IC 32-Bit Single-Core 48MHz 128KB (128K x 8) FLASH 100-TQFP (14x14) | |||
ATSAMC20N17A-ANT Microchip | от 352 ₽ | ||
ATSAMC20N17A-ANT Microchip | от 358 ₽ | ||
ATSAMC20N17A-ANT Microchip | 598 ₽ | ||
ATSAMC20N17A-ANT Microchip | по запросу |
ATSAMC20N17A-ANT | |
N | 1 |
Корпус | TQFP |
Количество выводов | 100 |
Parameters / Models | ATSAMC20N17A-ANT |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | Yes |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Configurable Logic Cell Modules, CLC | 4 |
EEPROM / HEF | 4096 / HEF |
Hardware Touch Peripheral | PTC |
High Voltage Capable | No |
I2C | 8 |
Internal Oscillator | 32khz, 32Khz ULP, 48Mhz |
Internal Voltage Reference, Bandgap | Yes |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 30 |
Max 16 Bit Digital Timers | 8 |
Max 8 Bit Digital Timers | 8 |
Max A/D Resolution, bits | 12 |
Max PWM Resolution, bits | 32 |
Max. CPU Speed MHz | 48 |
Рабочий диапазон температур, °C | от -40 до +105 |
Operation Voltage Max.(V) | 5.5 |
Operation Voltage Min.(V) | 2.7 |
Peripheral Pin Select, PPS | Yes |
Pin count | 100 |
Размер памяти программ, Kbytes | 128 |
RAM, bytes | 16384 |
SPIв„ў | 8 |
Temp. Range Max. | 105 |
Temp. Range Min. | -40 |
Total # of A/D channels | 12 |
UART | 8 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
ATSAMC20E15A ATSAMC20E16A ATSAMC20E17A ATSAMC20E18A ATSAMC20G15A ATSAMC20G16A ATSAMC20G17A ATSAMC20G18A ATSAMC20J15A ATSAMC20J16A ATSAMC20J17A ATSAMC20J18A ATSAMC20N18A ATSAMC21E17A ATSAMC21E18A ATSAMC21G17A ATSAMC21G18A ATSAMC21J17A ATSAMC21J18A ATSAMC21N17A ATSAMC21N18A
Серия: ATSAMC20N17A (1)
