Datasheet Microchip ATMEGA2561V-8AU — Даташит
Производитель | Microchip |
Серия | ATmega2561 |
Модель | ATMEGA2561V-8AU |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 256KB ISP flash memory, 8KB SRAM, 4KB EEPROM, 86 general purpose I/O lines, 32 general purpose working registers, real time counter, six flexible timer/counters with compare modes, PWM, 4 USARTs, byte oriented 2-wire serial interface, 8-channel 10-bit A/D converter, and a JTAG interface for on-chip debugging
Datasheet ATmega640/V-1280/V-1281/V-2560/V-2561/V - Complete
PDF, 8.8 Мб, Файл опубликован: 1 фев 2014, Страниц: 435
8-bit Atmel Microcontroller with 16/32/64KB In-System Programmable Flash
ATmega640/1280/1281/2560/2561 - Summary Datasheet
PDF, 1.0 Мб, Файл опубликован: 1 фев 2014
Купить ATMEGA2561V-8AU на РадиоЛоцман.Цены — от 296 до 5 389 ₽ 32 предложений от 20 поставщиков AVR AVR® ATmega Microcontroller IC 8-Bit 8MHz 256KB (128K x 16) FLASH 64-TQFP (14x14) | |||
ATMEGA2561V-8AU Microchip | 296 ₽ | ||
ATMEGA2561V-8AU Microchip | 393 ₽ | ||
ATMEGA2561V-8AU Microchip | 1 036 ₽ | ||
ATMEGA2561V8AU Atmel | по запросу |
Корпус | TQFP |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 4096 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 64 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 16 МГц |
Max PWM outputs | 8 including complementary |
Количество компараторов | 1 |
Package Width | 14x14x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 64 |
Размер памяти программ | 256 KB |
SPI | 3 |
SRAM | 8192 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
ATmega1280 ATmega1280V ATmega1281 ATmega2560 ATmega2560V ATmega2561V ATmega640 ATmega640V
Серия: ATmega2561 (9)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA2561V8AU, ATMEGA2561V 8AU
