Datasheet Microchip ATmega48PB — Даташит
Производитель | Microchip |
Серия | ATmega48PB |
The high-performance Microchip's AVR 8-bit RISC-based microcontroller with picoPower technology combines 4KB ISP Flash memory with read-while-write capabilities, 256B EEPROM, 512B SRAM, 27 general-purpose I/O lines, 32 general-purpose working registers, three flexible timer/counters with compare modes, internal and external interrupts, USART with wake-up on start of transmission, a byte-oriented 2-wire serial interface, SPI serial port, 8-channel 10-bit A/D converter, programmable watchdog timer with internal oscillator, a 9-byte unique serial number and five software selectable power-saving modes
ATmega48PB/88PB/168PB - Complete Datasheet
PDF, 6.1 Мб, Файл опубликован: 6 июл 2017
ATmega48PB/88PB/168PB - Summary Datasheet
PDF, 944 Кб, Файл опубликован: 6 июл 2017
Купить ATmega48PB на РадиоЛоцман.Цены — от 29 до 269 ₽ 27 предложений от 17 поставщиков AVR AVR® ATmega, Functional Safety (FuSa) Microcontroller IC 8-Bit 20MHz 4KB (2K x 16) FLASH 32-TQFP (7x7) | |||
ATMEGA48PB-AU Atmel | 29 ₽ | ||
ATMEGA48PB-AU Microchip | 56 ₽ | ||
ATMEGA48PB-AU Microchip | 72 ₽ | ||
ATMEGA48PB-MUR Microchip | по запросу |
ATMEGA48PB-AN | ATMEGA48PB-ANR | ATMEGA48PB-AU | ATMEGA48PB-AUR | ATMEGA48PB-MN | ATMEGA48PB-MNR | ATMEGA48PB-MU | ATMEGA48PB-MUR | |
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
Корпус | TQFP | TQFP | TQFP | TQFP | VQFN | VQFN | VQFN | VQFN |
Parameters / Models | ATMEGA48PB-AN | ATMEGA48PB-ANR | ATMEGA48PB-AU | ATMEGA48PB-AUR | ATMEGA48PB-MN | ATMEGA48PB-MNR | ATMEGA48PB-MU | ATMEGA48PB-MUR |
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
ADC with Computation | No | No | No | No | No | No | No | No |
Angular Timer | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No | No | No | No | No | No |
Class B Hardware | No | No | No | No | No | No | No | No |
Emulated EEPROM in Flash | 256 | 256 | 256 | 256 | 256 | 256 | 256 | 256 |
High Voltage Capable | No | No | No | No | No | No | No | No |
I2C | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Math Accelerator | No | No | No | No | No | No | No | No |
Max 8-Bit Digital Timers | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Max CPU Speed, МГц | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Max PWM outputs, including complementary | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Package Width | 7x7x1mm | 7x7x1mm | 7x7x1mm | 7x7x1mm | 5x5x0.9mm | 5x5x0.9mm | 5x5x0.9mm | 5x5x0.9mm |
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No |
Pin count | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Размер памяти программ, KB | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
SPI | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
SRAM, Bytes | 512 | 512 | 512 | 512 | 512 | 512 | 512 | 512 |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 |
UART | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Zero Cross detect | No | No | No | No | No | No | No | No |
Серия: ATmega48PB (8)
- Microcontrollers > 8-bit Microcontrollers
