Datasheet Microchip ATMEGA48A-MMH — Даташит
Производитель | Microchip |
Серия | ATmega48A |
Модель | ATMEGA48A-MMH |
The high-performance Microchip 8-bit AVR RISC-based microcontroller combines 4KB ISP flash memory, 256-Byte EEPROM, 512-Byte SRAM, 23 general purpose I/O lines, 32 general purpose working registers, three flexible timer/counters with compare modes, internal and external interrupts,serial programmable USART, a byte-oriented 2-wire serial interface, SPI serial port, 6-channel 10-bit A/D converter (8-channels in TQFP and QFN/MLF packages), programmable watchdog timer with internal oscillator, and five software selectable power saving modes
ATmega48A/88A/168A - Complete Datasheet
PDF, 3.8 Мб, Файл опубликован: 4 апр 2018
ATmega48A/88A/168A - Summary Datasheet
PDF, 438 Кб, Файл опубликован: 10 дек 2016
Купить ATMEGA48A-MMH на РадиоЛоцман.Цены — от 90 до 507 ₽ 26 предложений от 16 поставщиков IC: микроконтроллер AVR; EEPROM: 256Б; SRAM: 512Б; Flash: 4kБ; Cmp: 1 | |||
ATMEGA48A-MMH Microchip | 90 ₽ | ||
ATMEGA48A-MMH Microchip | 104 ₽ | ||
ATMEGA48A-MMH Microchip | 245 ₽ | ||
ATMEGA48A-MMH Microchip | от 498 ₽ |
Корпус | VQFN |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 256 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 6 including complementary |
Количество компараторов | 1 |
Package Width | 4x4x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 32 |
Размер памяти программ | 4 KB |
SPI | 2 |
SRAM | 512 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
Серия: ATmega48A (9)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA48AMMH, ATMEGA48A MMH
