Datasheet Microchip ATMEGA644PA-ANR — Даташит
Производитель | Microchip |
Серия | ATmega644PA |
Модель | ATMEGA644PA-ANR |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 64KB ISP flash memory with read-while-write capabilities, 2KB EEPROM, 4KB SRAM, 32 general purpose I/O lines, 32 general purpose working registers, a real time counter, three flexible timer/counters with compare modes and PWM, two USARTs, a byte oriented 2-wire serial interface, an 8-channel 10-bit A/D converter with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, SPI serial port, a JTAG (IEEE 1149
ATmega644PA - Complete Datasheet
PDF, 5.5 Мб, Файл опубликован: 10 дек 2016
ATmega644PA - Summary Datasheet
PDF, 410 Кб, Файл опубликован: 10 дек 2016
Купить ATMEGA644PA-ANR на РадиоЛоцман.Цены — от 330 до 1 230 ₽ 22 предложений от 13 поставщиков AVR AVR® ATmega Microcontroller IC 8-Bit 20MHz 64KB (32K x 16) FLASH 44-TQFP (10x10) | |||
ATMEGA644PA-ANR Microchip | 330 ₽ | ||
ATMEGA644PA-ANR Atmel | 459 ₽ | ||
ATMEGA644PA-ANR Microchip | 476 ₽ | ||
ATMEGA644PA-ANR Atmel | по запросу |
Корпус | TQFP |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 2048 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 44 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 6 including complementary |
Количество компараторов | 1 |
Package Width | 10x10x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 44 |
Размер памяти программ | 64 KB |
SPI | 3 |
SRAM | 4096 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
Серия: ATmega644PA (9)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA644PAANR, ATMEGA644PA ANR
