Datasheet Microchip ATMEGA324PA-CU — Даташит
Производитель | Microchip |
Серия | ATmega324PA |
Модель | ATMEGA324PA-CU |
The high-performance Microchip picoPower 8-bit AVR RISC-based microcontroller combines 32KB ISP flash memory with read-while-write capabilities, 1KB EEPROM, 2KB SRAM, 32 general purpose I/O lines, 32 general purpose working registers, a real time counter, three flexible timer/counters with compare modes and PWM, two USARTs, a byte oriented 2-wire serial interface, an 8-channel 10-bit A/D converter with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, SPI serial port, a JTAG (IEEE 1149
ATmega324PA - Complete Datasheet
PDF, 5.6 Мб, Файл опубликован: 10 дек 2016
ATmega324PA - Summary Datasheet
PDF, 520 Кб, Файл опубликован: 10 дек 2016
Купить ATMEGA324PA-CU на РадиоЛоцман.Цены — от 258 до 1 127 ₽ 22 предложений от 15 поставщиков IC: микроконтроллер AVR; EEPROM: 1кБ; SRAM: 2кБ; Flash: 32кБ; Cmp: 1 | |||
ATMEGA324PA-CU Microchip | 258 ₽ | ||
ATMEGA324PA-CU Microchip | по запросу | ||
ATMEGA324PA-CU Atmel | по запросу |
Корпус | VFBGA |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 1024 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 49 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 6 including complementary |
Количество компараторов | 1 |
Package Width | 5x5x1mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 44 |
Размер памяти программ | 32 KB |
SPI | 3 |
SRAM | 2048 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
Серия: ATmega324PA (14)
- Microcontrollers > 8-bit Microcontrollers
ATMEGA324PACU, ATMEGA324PA CU
