Datasheet Microchip ATSAMC20E18A-MUT — Даташит
Производитель | Microchip |
Серия | ATSAMC20E18A |
Модель | ATSAMC20E18A-MUT |
The Microchip SAM C series of 5V Cortex M0+ devices is designed for industrial and commercial applications in noisy environments
Купить ATSAMC20E18A-MUT на РадиоЛоцман.Цены — от 189 до 822 ₽ 12 предложений от 9 поставщиков ARM® Cortex®-M0+ SAM C20 Microcontroller IC 32-Bit Single-Core 48MHz 256KB (256K x 8) FLASH 32-VQFN (5x5) | |||
ATSAMC20E18A-MUT Atmel | 189 ₽ | ||
ATSAMC20E18A-MUT Microchip | 259 ₽ | ||
ATSAMC20E18A-MUT Microchip | 646 ₽ | ||
ATSAMC20E18A-MUT Microchip | по запросу |
Корпус | VQFN |
Количество выводов | 32 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | Yes |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Hardware Touch Peripheral | PTC |
High Voltage Capable | No |
I2C | 4 |
Internal Oscillator | 32khz, 32Khz ULP, 48Mhz |
Math Accelerator | No |
Max # PWM outputs | 22 including complementary outputs |
Max 8 Bit Digital Timers | 5 |
Max PWM Resolution | 32 bits |
Max. CPU Speed MHz | 48 |
Operation Voltage Max.(V) | 5.5 |
Operation Voltage Min.(V) | 2.7 |
Pin count | 32 |
Размер памяти программ | 256 Kbytes |
RAM | 32768 bytes |
SPIв„ў | 4 |
Signal Measurement Timer | 1 |
Temp. Range Max. | 105 |
Temp. Range Min. | -40 |
Total # of A/D channels | 10 |
UART | 4 |
Zero Cross detect | No |
ATSAMC20E15A ATSAMC20E16A ATSAMC20E17A ATSAMC20G15A ATSAMC20G16A ATSAMC20G17A ATSAMC20G18A ATSAMC20J15A ATSAMC20J16A ATSAMC20J17A ATSAMC20J18A ATSAMC20N17A ATSAMC20N18A ATSAMC21E17A ATSAMC21E18A ATSAMC21G17A ATSAMC21G18A ATSAMC21J17A ATSAMC21J18A ATSAMC21N17A ATSAMC21N18A
Серия: ATSAMC20E18A (4)
- ATSAMC20E18A-ANT ATSAMC20E18A-AUT ATSAMC20E18A-MNT ATSAMC20E18A-MUT
ATSAMC20E18AMUT, ATSAMC20E18A MUT
