Datasheet Microchip PIC16LF1779-E/P — Даташит
Производитель | Microchip |
Серия | PIC16F1779 |
Модель | PIC16LF1779-E/P |
PIC16(L)F177X microcontrollers feature a high level of integration of Intelligent Analog and digital peripherals for a wide range of applications, such as lighting, power supplies, battery charging, motor control and other general purpose applications
Datasheet PIC16F1777, PIC16F1778, PIC16F1779, PIC16LF1777, PIC16LF1778, PIC16LF1779
PDF, 7.6 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 630
28/40/44-Pin, 8-Bit Flash Microcontroller
Купить PIC16LF1779-E/P на РадиоЛоцман.Цены — от 287 до 300 ₽ 7 предложений от 7 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 28KB (16K x 14) FLASH 40-PDIP | |||
PIC16LF1779-E/P Microchip | 287 ₽ | ||
PIC16LF1779-E/P Microchip | 295 ₽ | ||
PIC16LF1779-E/P Microchip | 300 ₽ | ||
PIC16LF1779-E/P Microchip | по запросу |
Корпус | PDIP |
Количество выводов | 40 |
ADC Input | 28 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 4 |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 4 |
High Voltage Capable | No |
I2C | 1 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 5 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 10 Bits |
Max PWM outputs | 28 including complementary |
Количество компараторов | 8 |
Number of DACs | 8 |
Number of Op Amps | 4 |
Рабочий диапазон температур | от -40 до +125 °C |
PWM Max Resolution | 16 Bits |
Pin count | 40 |
Размер памяти программ | 28 KB |
SPI | 1 |
SRAM | 2048 Bytes |
Slope Compensation / Programmable Ramp Generator | 4 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F1779 (26)
- PIC16F1779-E/ML PIC16F1779-E/MLVAO PIC16F1779-E/MV PIC16F1779-E/P PIC16F1779-E/PT PIC16F1779-I/ML PIC16F1779-I/MV PIC16F1779-I/P PIC16F1779-I/PT PIC16F1779T-E/MLVAO PIC16F1779T-E/MV PIC16F1779T-I/ML PIC16F1779T-I/MV PIC16F1779T-I/PT PIC16F1779T-I/PTVAO PIC16LF1779-E/ML PIC16LF1779-E/MV PIC16LF1779-E/P PIC16LF1779-E/PT PIC16LF1779-I/ML PIC16LF1779-I/MV PIC16LF1779-I/P PIC16LF1779-I/PT PIC16LF1779T-I/ML PIC16LF1779T-I/MV PIC16LF1779T-I/PT
- Microcontrollers > 8-bit Microcontrollers
PIC16LF1779E/P, PIC16LF1779 E/P
