Datasheet Microchip PIC16LF1778T-I/SO — Даташит
Производитель | Microchip |
Серия | PIC16F1778 |
Модель | PIC16LF1778T-I/SO |
PIC16(L)F177X microcontrollers feature a high level of integration of Intelligent Analog and digital peripherals for a wide range of applications, such as lighting, power supplies, battery charging, motor control and other general purpose applications
Datasheet PIC16F1777, PIC16F1778, PIC16F1779, PIC16LF1777, PIC16LF1778, PIC16LF1779
PDF, 7.6 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 630
28/40/44-Pin, 8-Bit Flash Microcontroller
Купить PIC16LF1778T-I/SO на РадиоЛоцман.Цены — от 195 до 198 ₽ 7 предложений от 7 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 28KB (16K x 14) FLASH 28-SOIC | |||
PIC16LF1778T-I/SO Microchip | 195 ₽ | ||
PIC16LF1778T-I/SO Microchip | 198 ₽ | ||
PIC16LF1778T-I/SO Microchip | по запросу | ||
Корпус | SOIC |
Количество выводов | 28 |
ADC Input | 17 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 3 |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 4 |
High Voltage Capable | No |
I2C | 1 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 5 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 10 Bits |
Max PWM outputs | 21 including complementary |
Количество компараторов | 6 |
Number of DACs | 6 |
Number of Op Amps | 3 |
PWM Max Resolution | 16 Bits |
Pin count | 28 |
Размер памяти программ | 28 KB |
SPI | 1 |
SRAM | 2048 Bytes |
Slope Compensation / Programmable Ramp Generator | 3 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F1778 (24)
- PIC16F1778-E/MX PIC16F1778-E/SO PIC16F1778-E/SP PIC16F1778-E/SS PIC16F1778-I/MX PIC16F1778-I/SO PIC16F1778-I/SP PIC16F1778-I/SS PIC16F1778T-E/MX PIC16F1778T-E/SS PIC16F1778T-I/MX PIC16F1778T-I/SO PIC16F1778T-I/SS PIC16LF1778-E/MX PIC16LF1778-E/SO PIC16LF1778-E/SP PIC16LF1778-E/SS PIC16LF1778-I/MX PIC16LF1778-I/SO PIC16LF1778-I/SP PIC16LF1778-I/SS PIC16LF1778T-I/MX PIC16LF1778T-I/SO PIC16LF1778T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16LF1778TI/SO, PIC16LF1778T I/SO
