Datasheet Microchip PIC16F1778-E/SP — Даташит
Производитель | Microchip |
Серия | PIC16F1778 |
Модель | PIC16F1778-E/SP |
PIC16(L)F177X microcontrollers feature a high level of integration of Intelligent Analog and digital peripherals for a wide range of applications, such as lighting, power supplies, battery charging, motor control and other general purpose applications.
28/40/44-Pin, 8-Bit Flash Microcontroller
Купить PIC16F1778-E/SP на РадиоЛоцман.Цены — от 234 до 245 ₽ 7 предложений от 7 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 28KB (16K x 14) FLASH 28-SPDIP | |||
PIC16F1778-E/SP Microchip | 234 ₽ | ||
PIC16F1778-E/SP Microchip | 241 ₽ | ||
PIC16F1778-E/SP Microchip | по запросу | ||
These devices deliver multiple Op Amps, 5-/10-bit DACs, High-Speed Comparators, 10-bit ADC, 10-/16-bit PWMs, Programmable Ramp Generator (PRG) and other peripherals that can be connected internally to create closed loop systems without using pins or PCB area. The 10 and 16-bit PWMs, the Digital Signal Modulator (DSM) and tri-state output Op Amp can be used together to create a LED dimming engine. The Peripheral Pin Select (PPS) functionality provides flexibility, eases PCB layout and peripheral utilization by allowing digital peripheral pin mapping to any I/O.
Корпус | SPDIP |
ADC Input | 17 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | Yes |
Complementary Waveform Generator / Complementary Output Generator | 4 |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 3 |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 4 |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 28 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 5 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 10 Bits |
Max PWM outputs | 21 including complementary |
Количество компараторов | 6 |
Number of DACs | 6 |
Number of Op Amps | 3 |
PWM Max Resolution | 16 Bits |
Package Width | .300in |
Pin count | 28 |
Размер памяти программ | 28 KB |
SPI | 1 |
SRAM | 2048 Bytes |
Slope Compensation / Programmable Ramp Generator | Yes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
- PIC16F1778-E/MX PIC16F1778-E/SO PIC16F1778-E/SP PIC16F1778-E/SS PIC16F1778-I/MX PIC16F1778-I/SO PIC16F1778-I/SP PIC16F1778-I/SS PIC16F1778T-E/MX PIC16F1778T-E/SS PIC16F1778T-I/MX PIC16F1778T-I/SO PIC16F1778T-I/SS PIC16LF1778-E/MX PIC16LF1778-E/SO PIC16LF1778-E/SP PIC16LF1778-E/SS PIC16LF1778-I/MX PIC16LF1778-I/SO PIC16LF1778-I/SP PIC16LF1778-I/SS PIC16LF1778T-I/MX PIC16LF1778T-I/SO PIC16LF1778T-I/SS
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1778E/SP, PIC16F1778 E/SP
