Datasheet Microchip PIC16F1777-E/MV — Даташит
Производитель | Microchip |
Серия | PIC16F1777 |
Модель | PIC16F1777-E/MV |
PIC16(L)F177X microcontrollers feature a high level of integration of Intelligent Analog and digital peripherals for a wide range of applications, such as lighting, power supplies, battery charging, motor control and other general purpose applications.
28/40/44-Pin, 8-Bit Flash Microcontroller
Купить PIC16F1777-E/MV на РадиоЛоцман.Цены — от 245 до 250 ₽ 7 предложений от 7 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 14KB (8K x 14) FLASH 40-UQFN (5x5) | |||
PIC16F1777-E/MV Microchip | 245 ₽ | ||
PIC16F1777-E/MV Microchip | 248 ₽ | ||
PIC16F1777-E/MV Microchip | 250 ₽ | ||
PIC16F1777-E/MV Microchip | по запросу |
These devices deliver multiple Op Amps, 5-/10-bit DACs, High-Speed Comparators, 10-bit ADC, 10-/16-bit PWMs, Programmable Ramp Generator (PRG) and other peripherals that can be connected internally to create closed loop systems without using pins or PCB area. The 10 and 16-bit PWMs, the Digital Signal Modulator (DSM) and tri-state output Op Amp can be used together to create a LED dimming engine. The Peripheral Pin Select (PPS) functionality provides flexibility, eases PCB layout and peripheral utilization by allowing digital peripheral pin mapping to any I/O.
Корпус | UQFN |
ADC Input | 28 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 4 |
Configurable Logic Cell | 4 CLC/CCL |
Data Signal Modulator | 4 |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 4 |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 40 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 5 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 10 Bits |
Max PWM outputs | 28 including complementary |
Количество компараторов | 8 |
Number of DACs | 8 |
Number of Op Amps | 4 |
PWM Max Resolution | 16 Bits |
Package Width | 5x5x0.5mm |
Pin count | 40 |
Размер памяти программ | 14 KB |
SPI | 1 |
SRAM | 1024 Bytes |
Slope Compensation / Programmable Ramp Generator | Yes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
- PIC16F1777-E/ML PIC16F1777-E/MLVAO PIC16F1777-E/MV PIC16F1777-E/P PIC16F1777-E/PT PIC16F1777-I/ML PIC16F1777-I/MV PIC16F1777-I/P PIC16F1777-I/PT PIC16F1777T-E/MLVAO PIC16F1777T-I/ML PIC16F1777T-I/MV PIC16F1777T-I/PT PIC16LF1777-E/ML PIC16LF1777-E/MV PIC16LF1777-E/P PIC16LF1777-E/PT PIC16LF1777-I/ML PIC16LF1777-I/MV PIC16LF1777-I/P PIC16LF1777-I/PT PIC16LF1777T-I/ML PIC16LF1777T-I/MV PIC16LF1777T-I/PT
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1777E/MV, PIC16F1777 E/MV
