Datasheet Microchip PIC16F1768T-E/ML — Даташит
Производитель | Microchip |
Серия | PIC16F1768 |
Модель | PIC16F1768T-E/ML |
PIC16(L)F176X microcontrollers combine intelligent analog integration with digital peripherals to suit a variety of functions and applications.
Datasheet PIC16F1764, PIC16F1765, PIC16F1768, PIC16F1769, PIC16LF1764, PIC16LF1765, PIC16LF1768, PIC16LF1769
PDF, 9.6 Мб, Язык: анг., Файл закачен: 8 ноя 2019, Страниц: 568
14/20-Pin, 8-Bit Flash Microcontrollers
PIC16(L)F1764/5/8/9 14/20-Pin, 8-Bit Flash MCU Data Sheet
PDF, 7.9 Мб, Файл опубликован: 5 мар 2018
Купить PIC16F1768T-E на РадиоЛоцман.Цены — от 64 до 135 ₽ 15 предложений от 9 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 7KB (4K x 14) FLASH 20-SOIC | |||
PIC16F1768T-I/ML Microchip | от 64 ₽ | ||
PIC16F1768T-I/ML Microchip | от 65 ₽ | ||
PIC16F1768T-I/SS Microchip | 135 ₽ | ||
These 14/20-pin devices provide features like 10-bit A/D, op amps, zero cross detect, high current IOs, programmable ramp generator: (slope compensation & ramp generation), communication, peripheral pin select and other key peripherals that make this family appealing in applications looking for design flexibility.
Корпус | QFN |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 2 |
Configurable Logic Cell | 3 CLC/CCL |
Data Signal Modulator | 2 |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 3 |
High Voltage Capable | No |
I2C | 1 |
Lead Count | 20 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 10 Bits |
Max PWM outputs | 12 including complementary |
Количество компараторов | 4 |
Number of DACs | 4 |
Number of Op Amps | 2 |
PWM Max Resolution | 16 Bits |
Package Width | 4x4x0.9mm |
Pin count | 20 |
Размер памяти программ | 7 KB |
SPI | 1 |
SRAM | 512 Bytes |
Slope Compensation / Programmable Ramp Generator | Yes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
PIC16F1764 PIC16F1765 PIC16F1769
Серия: PIC16F1768 (24)
- PIC16F1768-E/ML PIC16F1768-E/P PIC16F1768-E/SO PIC16F1768-E/SS PIC16F1768-I/ML PIC16F1768-I/P PIC16F1768-I/SO PIC16F1768-I/SS PIC16F1768T-E/6NVAO PIC16F1768T-E/ML PIC16F1768T-I/ML PIC16F1768T-I/SO PIC16F1768T-I/SS PIC16LF1768-E/ML PIC16LF1768-E/P PIC16LF1768-E/SO PIC16LF1768-E/SS PIC16LF1768-I/ML PIC16LF1768-I/P PIC16LF1768-I/SO PIC16LF1768-I/SS PIC16LF1768T-I/ML PIC16LF1768T-I/SO PIC16LF1768T-I/SS
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1768TE/ML, PIC16F1768T E/ML
