Datasheet Microchip PIC16LF1768T-I/ML — Даташит
Производитель | Microchip |
Серия | PIC16F1768 |
Модель | PIC16LF1768T-I/ML |
PIC16(L)F176X microcontrollers combine intelligent analog integration with digital peripherals to suit a variety of functions and applications
PIC16(L)F1764/5/8/9 14/20-Pin, 8-Bit Flash MCU Data Sheet
PDF, 7.9 Мб, Файл опубликован: 5 мар 2018
Купить PIC16LF1768T-I/ML на РадиоЛоцман.Цены — от 92 до 139 ₽ 8 предложений от 8 поставщиков PIC PIC® XLPTM16F Microcontroller IC 8-Bit 32MHz 7KB (4K x 14) FLASH 20-QFN (4x4) | |||
PIC16LF1768T-I/ML Microchip | 92 ₽ | ||
PIC16LF1768T-I/ML Microchip | 135 ₽ | ||
PIC16LF1768T-I/ML Microchip | 137 ₽ | ||
PIC16LF1768T-I/ML Microchip | 139 ₽ |
Корпус | QFN |
Количество выводов | 20 |
ADC Input | 12 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Complementary Waveform Generator / Complementary Output Generator | 2 |
Configurable Logic Cell | 3 CLC/CCL |
Data Signal Modulator | 2 |
Emulated EEPROM in Flash | 0 / HEF |
Hardware Limit Timer | 3 |
High Voltage Capable | No |
I2C | 1 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 3 |
Max 8-Bit Digital Timers | 4 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 10 Bits |
Max PWM outputs | 12 including complementary |
Количество компараторов | 4 |
Number of DACs | 4 |
Number of Op Amps | 2 |
PWM Max Resolution | 16 Bits |
Pin count | 20 |
Размер памяти программ | 7 KB |
SPI | 1 |
SRAM | 512 Bytes |
Slope Compensation / Programmable Ramp Generator | 2 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | Yes |
Серия: PIC16F1768 (24)
- PIC16F1768-E/ML PIC16F1768-E/P PIC16F1768-E/SO PIC16F1768-E/SS PIC16F1768-I/ML PIC16F1768-I/P PIC16F1768-I/SO PIC16F1768-I/SS PIC16F1768T-E/6NVAO PIC16F1768T-E/ML PIC16F1768T-I/ML PIC16F1768T-I/SO PIC16F1768T-I/SS PIC16LF1768-E/ML PIC16LF1768-E/P PIC16LF1768-E/SO PIC16LF1768-E/SS PIC16LF1768-I/ML PIC16LF1768-I/P PIC16LF1768-I/SO PIC16LF1768-I/SS PIC16LF1768T-I/ML PIC16LF1768T-I/SO PIC16LF1768T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16LF1768TI/ML, PIC16LF1768T I/ML
