Datasheet Microchip PIC24FJ128GB108 — Даташит
Производитель | Microchip |
Серия | PIC24FJ128GB108 |
Ideal for low power (<100nA standby current) and connectivity applications that benefit from the availability of multiple serial ports (3xI2C, 3xSPI), 4xUARTS, and 23 independent timers
Купить PIC24FJ128GB108 на РадиоЛоцман.Цены — от 313 до 2 874 ₽ 25 предложений от 15 поставщиков MICROCHIP PIC24FJ128GB108-I/PT 16Bit Microcontroller, USB On The Go, PIC24FJxxxGBxxx, 32MHz, 128KB, 16KB, 80Pins, TQFP | |||
PIC24FJ128GB108-I/PT Microchip | 313 ₽ | ||
PIC24FJ128GB108T-I/PT Microchip | 443 ₽ | ||
PIC24FJ128GB108-I/PT Microchip | от 1 482 ₽ | ||
PIC24FJ128GB108-I/PT Microchip | по запросу |
PIC24FJ128GB108-I/PT | |
N | 1 |
Корпус | TQFP |
Количество выводов | 80 |
Parameters / Models | PIC24FJ128GB108-I/PT |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit PIC MCU |
CRC/Scan | Yes |
Cap. Touch Channels | 16 |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 3 |
Internal Oscillator | 8 MHz, 31 kHz |
Internal Voltage Reference, Bandgap | No |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 9 |
Max 16 Bit Digital Timers | 23 |
Max A/D Resolution, bits | 10 |
Max PWM Resolution, bits | 16 |
Max. CPU Speed MHz | 32 |
Number of USB Modules | 1 |
Рабочий диапазон температур, °C | от -40 до +85 |
Operation Voltage Min.(V) | 2 |
Peripheral Pin Select, PPS | Yes |
Pin count | 80 |
Размер памяти программ, Kbytes | 128 |
RAM, bytes | 16384 |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 4 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
PIC24FJ128GB106 PIC24FJ128GB110 PIC24FJ192GB106 PIC24FJ192GB108 PIC24FJ192GB110 PIC24FJ256GB106 PIC24FJ256GB108 PIC24FJ256GB110 PIC24FJ64GB106 PIC24FJ64GB108 PIC24FJ64GB110
Серия: PIC24FJ128GB108 (1)
