Datasheet Microchip PIC16LF1575-I/ST — Даташит
Производитель | Microchip |
Серия | PIC16F1575 |
Модель | PIC16LF1575-I/ST |
PIC16(L)F157X microcontrollers combine the capabilities of 16-bit PWMs with Analog to suit a variety of applications
Datasheet PIC16F1574, PIC16F1575, PIC16F1578, PIC16F1579, PIC16LF1574, PIC16LF1575, PIC16LF1578, PIC16LF1579
PDF, 4.1 Мб, Язык: анг., Файл закачен: 6 ноя 2017, Страниц: 342
14/20-Pin MCUs with High-Precision 16-Bit PWMs
Купить PIC16LF1575-I/ST на РадиоЛоцман.Цены — от 61 до 237 ₽ 11 предложений от 9 поставщиков PIC PIC® 16F Microcontroller IC 8-Bit 32MHz 14KB (8K x 14) FLASH 14-TSSOP | |||
PIC16LF1575-I/ST Microchip | 61 ₽ | ||
PIC16LF1575-I/ST Microchip | 90 ₽ | ||
PIC16LF1575-I/ST Microchip | 91 ₽ | ||
PIC16LF1575-I/ST Microchip | от 237 ₽ |
Корпус | TSSOP |
Количество выводов | 14 |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
Math Accelerator | No |
Max 16-Bit Digital Timers | 9 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 6 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
PWM Max Resolution | 16 Bits |
Pin count | 14 |
Размер памяти программ | 14 KB |
SRAM | 1024 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
PIC16F1574 PIC16F1578 PIC16F1579
Серия: PIC16F1575 (27)
- PIC16F1575-E/JQ PIC16F1575-E/P PIC16F1575-E/SL PIC16F1575-E/SLVAO PIC16F1575-E/ST PIC16F1575-I/JQ PIC16F1575-I/P PIC16F1575-I/SL PIC16F1575-I/ST PIC16F1575T-E/JQ PIC16F1575T-E/SL PIC16F1575T-E/SLVAO PIC16F1575T-E/ST PIC16F1575T-I/JQ PIC16F1575T-I/SL PIC16F1575T-I/ST PIC16LF1575-E/JQ PIC16LF1575-E/P PIC16LF1575-E/SL PIC16LF1575-E/ST PIC16LF1575-I/JQ PIC16LF1575-I/P PIC16LF1575-I/SL PIC16LF1575-I/ST PIC16LF1575T-I/JQ PIC16LF1575T-I/SL PIC16LF1575T-I/ST
- Microcontrollers > 8-bit Microcontrollers
PIC16LF1575I/ST, PIC16LF1575 I/ST
