Datasheet Microchip PIC16F1575-I/P — Даташит
Производитель | Microchip |
Серия | PIC16F1575 |
Модель | PIC16F1575-I/P |
PIC16(L)F157X microcontrollers combine the capabilities of 16-bit PWMs with Analog to suit a variety of applications.
14/20-Pin MCUs with High-Precision 16-Bit PWMs
Купить PIC16F1575-I/P на РадиоЛоцман.Цены — от 68 до 320 ₽ 22 предложений от 13 поставщиков IC: микроконтроллер PIC; Память: 14кБ; SRAM: 1кБ; 32МГц; 2,3÷5,5ВDC | |||
PIC16F1575-I/P Microchip | 68 ₽ | ||
PIC16F1575-I/P Microchip | 102 ₽ | ||
PIC16F1575-I/P Microchip | от 162 ₽ | ||
PIC16F1575-I/P Microchip | по запросу |
These devices deliver four 16-bit PWMs with independent timers, for applications where high resolution is needed, such as LED lighting, stepper motors, power supplies and other general-purpose applications. The core independent peripherals (16-bit PWMs, Complementary Waveform Generator) and Analog (ADCs, Comparator and DAC) can be configured for closed loop feedback control or other application needs. The Peripheral Pin Select (PPS) functionality allows for I/O pin remapping of the digital peripherals for increased flexility. The EUSART peripheral enables serial communication for use in multiple market segments, such as LIN applications. Debug Support • Debug and Programming support is available via PICkit™ 3, and MPLAB® ICD 3 Demonstration Platform Precision RGB LED color mix with interactive control via mTouch Technology slider, PC Chromaticity Selector GUI, and auto rotation of predetermined color palette. www.microchip.com/rgbbadge
Корпус | PDIP |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | No |
Class B Support | No |
Emulated EEPROM in Flash | 0 / HEF |
High Voltage Capable | No |
Lead Count | 14 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 9 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 32 МГц |
Max DAC Resolution | 5 Bits |
Max PWM outputs | 6 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
PWM Max Resolution | 16 Bits |
Package Width | .300in |
Pin count | 14 |
Размер памяти программ | 14 KB |
SRAM | 1024 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 1 |
Zero Cross detect | No |
PIC16F1574 PIC16F1578 PIC16F1579
- PIC16F1575-E/JQ PIC16F1575-E/P PIC16F1575-E/SL PIC16F1575-E/SLVAO PIC16F1575-E/ST PIC16F1575-I/JQ PIC16F1575-I/P PIC16F1575-I/SL PIC16F1575-I/ST PIC16F1575T-E/JQ PIC16F1575T-E/SL PIC16F1575T-E/SLVAO PIC16F1575T-E/ST PIC16F1575T-I/JQ PIC16F1575T-I/SL PIC16F1575T-I/ST PIC16LF1575-E/JQ PIC16LF1575-E/P PIC16LF1575-E/SL PIC16LF1575-E/ST PIC16LF1575-I/JQ PIC16LF1575-I/P PIC16LF1575-I/SL PIC16LF1575-I/ST PIC16LF1575T-I/JQ PIC16LF1575T-I/SL PIC16LF1575T-I/ST
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1575I/P, PIC16F1575 I/P
