Datasheet Microchip DSPIC33EP16GS202T-E/MX — Даташит
Производитель | Microchip |
Серия | dsPIC33EP16GS202 |
Модель | DSPIC33EP16GS202T-E/MX |
dsPIC33EPXXGS202 is a SMPS & Digital Power Conversion Digital Signal Controller
Купить DSPIC33EP16GS202T-E/MX на РадиоЛоцман.Цены — от 267 до 648 ₽ 6 предложений от 6 поставщиков dsPIC Automotive, AEC-Q100, dsPICTM33EP, Functional Safety (FuSa) Microcontroller IC 16-Bit 60 MIPs 16KB (16K x 8) FLASH 28-UQFN (6x6) | |||
DSPIC33EP16GS202T-E/MX Microchip | 267 ₽ | ||
DSPIC33EP16GS202T-E/MX Microchip | 639 ₽ | ||
DSPIC33EP16GS202T-E/MX Microchip | 648 ₽ | ||
DSPIC33EP16GS202T-E/MX Microchip | по запросу |
Статус продукта | Samples Available |
Корпус | UQFN |
Количество выводов | 28 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 6 including complementary outputs |
Max 16 Bit Digital Timers | 3 |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 70 |
Number of D/A Converters | 2 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 16 Kbytes |
RAM | 2048 bytes |
SPIв„ў | 1 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 12 |
UART | 1 |
Zero Cross detect | No |
Серия: dsPIC33EP16GS202 (22)
- DSPIC33EP16GS202-E/M6 DSPIC33EP16GS202-E/MM DSPIC33EP16GS202-E/MX DSPIC33EP16GS202-E/SO DSPIC33EP16GS202-E/SS DSPIC33EP16GS202-E/SSVAO DSPIC33EP16GS202-I/M6 DSPIC33EP16GS202-I/MM DSPIC33EP16GS202-I/MX DSPIC33EP16GS202-I/SO DSPIC33EP16GS202-I/SS DSPIC33EP16GS202T-E/M6 DSPIC33EP16GS202T-E/MM DSPIC33EP16GS202T-E/MX DSPIC33EP16GS202T-E/SO DSPIC33EP16GS202T-E/SS DSPIC33EP16GS202T-E/SSVAO DSPIC33EP16GS202T-I/M6 DSPIC33EP16GS202T-I/MM DSPIC33EP16GS202T-I/MX DSPIC33EP16GS202T-I/SO DSPIC33EP16GS202T-I/SS
DSPIC33EP16GS202TE/MX, DSPIC33EP16GS202T E/MX
