Datasheet Microchip DSPIC33EP128GS808-E/PTVAO — Даташит
Производитель | Microchip |
Серия | dsPIC33EP128GS808 |
Модель | DSPIC33EP128GS808-E/PTVAO |
dsPIC33EPXXGS70X/80X is a SMPS & Digital Power Conversion Digital Signal Controller
Купить DSPIC33EP128GS808-E на РадиоЛоцман.Цены — от 501 до 2 262 ₽ 24 предложений от 12 поставщиков dsPIC dsPICTM33EP, Functional Safety (FuSa) Microcontroller IC 16-Bit 70 MIPs 128KB (43K x 24) FLASH 80-TQFP (12x12) | |||
DSPIC33EP128GS808-I/PT Microchip | 501 ₽ | ||
DSPIC33EP128GS808-I/PT Microchip | 1 231 ₽ | ||
DSPIC33EP128GS808-I/PT Microchip | от 1 353 ₽ | ||
DSPIC33EP128GS808T-I/PT Microchip | по запросу |
Корпус | TQFP |
Количество выводов | 80 |
# of Comparators | 4 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
Configurable Logic Cell Modules | 4 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 10 including complementary outputs |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 70 |
Number of D/A Converters | 4 |
Operation Voltage Min.(V) | 3 |
Pin count | 80 |
Размер памяти программ | 128 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 22 |
UART | 2 |
Zero Cross detect | No |
dsPIC33EP128GS702 dsPIC33EP128GS704 dsPIC33EP128GS705 dsPIC33EP128GS706 dsPIC33EP128GS708 dsPIC33EP128GS804 dsPIC33EP128GS805 dsPIC33EP128GS806 dsPIC33EP64GS708 dsPIC33EP64GS804 dsPIC33EP64GS805 dsPIC33EP64GS806 dsPIC33EP64GS808
Серия: dsPIC33EP128GS808 (6)
- DSPIC33EP128GS808-E/PT DSPIC33EP128GS808-E/PTVAO DSPIC33EP128GS808-I/PT DSPIC33EP128GS808T-E/PT DSPIC33EP128GS808T-E/PTVAO DSPIC33EP128GS808T-I/PT
DSPIC33EP128GS808E/PTVAO, DSPIC33EP128GS808 E/PTVAO
