Datasheet Microchip ATSAML22J17A-MUT — Даташит
Производитель | Microchip |
Серия | ATSAML22J17A |
Модель | ATSAML22J17A-MUT |
The ultra-low-power ATSAML22 based Flash microcontrollers (MCU) feature sophisticated power management technologies and consumes 39 µA/MHz (CPU running CoreMark) in active mode and down to 490nA in ultra low-power backup mode with RTC
Купить ATSAML22J17A-MUT на РадиоЛоцман.Цены — от 221 до 294 ₽ 8 предложений от 8 поставщиков ARM® Cortex®-M0+ SAM L22J Microcontroller IC 32-Bit Single-Core 32MHz 128KB (128K x 8) FLASH 64-QFN (9x9) | |||
ATSAML22J17A-MUT Atmel | 221 ₽ | ||
ATSAML22J17A-MUT Atmel | 250 ₽ | ||
ATSAML22J17A-MUT Atmel | 256 ₽ | ||
ATSAML22J17A-MUT Microchip | 294 ₽ |
Корпус | VQFN |
Количество выводов | 64 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Cap. Touch Channels | 182 |
High Voltage Capable | No |
I2C | 4 |
Internal Oscillator | 32Khz ULP, 16Mhz |
Math Accelerator | No |
Max # PWM outputs | 12 including complementary outputs |
Max 16 Bit Digital Timers | 4 |
Max 8 Bit Digital Timers | 4 |
Max. CPU Speed MHz | 32 |
Number of USB Modules | 1 |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 64 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 4 |
Segment LCD | 184 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 4 |
Zero Cross detect | No |
ATSAML22G16A ATSAML22G17A ATSAML22G18A ATSAML22J16A ATSAML22J18A ATSAML22N16A ATSAML22N17A ATSAML22N18A
Серия: ATSAML22J17A (2)
- ATSAML22J17A-AUT ATSAML22J17A-MUT
ATSAML22J17AMUT, ATSAML22J17A MUT
