Datasheet Microchip ATSAML21E17B-ANT — Даташит
Производитель | Microchip |
Серия | ATSAML21E17B |
Модель | ATSAML21E17B-ANT |
The ultra-low-power ATSAML21 based Flash microcontroller (MCU) feature sophisticated power management technologies and consumes under 35 µA/MHz in active mode and 200nA in Sleep mode
Купить ATSAML21E17B-ANT на РадиоЛоцман.Цены — от 198 до 890 ₽ 26 предложений от 14 поставщиков ARM® Cortex®-M0+ SAM L21E Microcontroller IC 32-Bit Single-Core 48MHz 128KB (128K x 8) FLASH 32-TQFP (7x7) | |||
ATSAML21E17B-MUT Microchip | 198 ₽ | ||
ATSAML21E17B-AUT/MUT Atmel | 243 ₽ | ||
ATSAML21E17B-AUT Microchip | 292 ₽ | ||
ATSAML21E17B-AUT Microchip | 296 ₽ |
Корпус | TQFP |
Количество выводов | 32 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Cap. Touch Channels | 60 |
Configurable Logic Cell Modules | 4 CLC |
High Voltage Capable | No |
I2C | 4 |
Internal Oscillator | 32Khz ULP, 16Mhz |
Math Accelerator | No |
Max # PWM outputs | 18 including complementary outputs |
Max 8 Bit Digital Timers | 5 |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 48 |
Number of D/A Converters | 2 |
Number of USB Modules | 1 |
Рабочий диапазон температур | от -40 до +105 °C |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 1.62 |
Operational Amplifier | 3 |
Pin count | 32 |
Размер памяти программ | 128 Kbytes |
RAM | 24576 bytes |
SPIв„ў | 4 |
Temp. Range Max. | 105 |
Temp. Range Min. | -40 |
Total # of A/D channels | 10 |
UART | 4 |
Zero Cross detect | No |
ATSAML21E15B ATSAML21E16B ATSAML21E18B ATSAML21G16B ATSAML21G17B ATSAML21G18B ATSAML21J16B ATSAML21J17B ATSAML21J18B
Серия: ATSAML21E17B (4)
- ATSAML21E17B-ANT ATSAML21E17B-AUT ATSAML21E17B-MNT ATSAML21E17B-MUT
ATSAML21E17BANT, ATSAML21E17B ANT
