Datasheet Microchip ATSAMD11D14A-MUT — Даташит
Производитель | Microchip |
Серия | ATSAMD11D14 |
Модель | ATSAMD11D14A-MUT |
A low-power, high-performance ARM® Cortex®-M0+ based flash microcontroller, the Microchip's ATSAMD11D14 is ideal for a wide range of home automation, consumer, metering, and industrial applications
Купить ATSAMD11D14A-MUT на РадиоЛоцман.Цены — от 83 до 1 129 ₽ 21 предложений от 12 поставщиков MICROCHIP - ATSAMD11D14A-MUT - ARM MCU, seria SAM D, SAM32 Family SAM D1X Series Microcontrollers, ARM Cortex-M0+, 32 bity, 48 MHz... | |||
ATSAMD11D14A-MUT Microchip | 83 ₽ | ||
ATSAMD11D14A-MUT Microchip | 123 ₽ | ||
ATSAMD11D14A-MUT Microchip | от 1 129 ₽ | ||
ATSAMD11D14A-MUT Microchip | по запросу |
Корпус | VQFN |
Количество выводов | 24 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
Cap. Touch Channels | 72 |
High Voltage Capable | No |
I2C | 3 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Math Accelerator | No |
Max # PWM outputs | 12 including complementary outputs |
Max 16 Bit Digital Timers | 2 |
Max 8 Bit Digital Timers | 2 |
Max D/A Resolution | 10 bits |
Max. CPU Speed MHz | 48 |
Number of USB Modules | 1 |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 24 |
Размер памяти программ | 16 Kbytes |
RAM | 4096 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 10 |
UART | 3 |
Zero Cross detect | No |
Серия: ATSAMD11D14 (5)
- ATSAMD11D14A-MNT ATSAMD11D14A-MUT ATSAMD11D14A-SSNT ATSAMD11D14A-SSUT ATSAMD11D14A-UUT
ATSAMD11D14AMUT, ATSAMD11D14A MUT
