Datasheet Microchip ATSAMD09D14 — Даташит
Производитель | Microchip |
Серия | ATSAMD09D14 |
The low-power Microchip's ATSAMD09D14 ARM® Cortex®-M0+ based Flash microcontroller is ideal for a wide range of home automation, consumer, metering and industrial applications
Купить ATSAMD09D14 на РадиоЛоцман.Цены — от 34 до 297 ₽ 25 предложений от 13 поставщиков ARM® Cortex®-M0+ SAM D09D Microcontroller IC 32-Bit Single-Core 48MHz 16KB (16K x 8) FLASH 24-QFN (4x4) | |||
ATSAMD09D14A-MUT Microchip | 34 ₽ | ||
ATSAMD09D14A-MUT Microchip | 105 ₽ | ||
ATSAMD09D14A-MUT Microchip | от 292 ₽ | ||
ATSAMD09D14A-MUT Microchip | по запросу |
ATSAMD09D14A-MUT | |
N | 1 |
Корпус | VQFN |
Количество выводов | 24 |
Parameters / Models | ATSAMD09D14A-MUT |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Internal Voltage Reference, Bandgap | Yes |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 4 |
Max 16 Bit Digital Timers | 2 |
Max 8 Bit Digital Timers | 2 |
Max A/D Resolution, bits | 12 |
Max. CPU Speed MHz | 48 |
Рабочий диапазон температур, °C | от -40 до +85 |
Operation Voltage Min.(V) | 2.4 |
Peripheral Pin Select, PPS | Yes |
Pin count | 14 |
Размер памяти программ, Kbytes | 16 |
RAM, bytes | 4096 |
SPIв„ў | 2 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 5 |
UART | 2 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
Серия: ATSAMD09D14 (1)
