Datasheet Microchip ATSAM4SD32BA-AU — Даташит
Производитель | Microchip |
Серия | ATSAM4SD32B |
Модель | ATSAM4SD32BA-AU |
Microchip's ARM®-based SAM4SD32 microcontroller builds on the high-performance 32-bit Cortex®-M4 core.
Купить ATSAM4SD32BA-AU на РадиоЛоцман.Цены — от 565 до 2 304 ₽ 19 предложений от 15 поставщиков ARM® Cortex®-M4 SAM4S Microcontroller IC 32-Bit Single-Core 120MHz 2MB (2M x 8) FLASH 64-LQFP (10x10) | |||
ATSAM4SD32BA-AU Microchip | 565 ₽ | ||
ATSAM4SD32BA-AU Microchip | 572 ₽ | ||
ATSAM4SD32BA-AU Atmel | 882 ₽ | ||
ATSAM4SD32BA-AU Atmel | 952 ₽ |
Корпус | LQFP |
Количество выводов | 64 |
# of Comparators | 1 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4 |
CRC/Scan | No |
Cap. Touch Channels | 23 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 4,8,12Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 4 including complementary outputs |
Max 16 Bit Digital Timers | 6 |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 120 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 64 |
Размер памяти программ | 2048 Kbytes |
RAM | 163840 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 10 |
UART | 4 |
Zero Cross detect | No |
ATSAM4S16B ATSAM4S16C ATSAM4S2A ATSAM4S2B ATSAM4S2C ATSAM4S4A ATSAM4S4B ATSAM4S4C ATSAM4S8B ATSAM4S8C ATSAM4SA16B ATSAM4SA16C ATSAM4SD16B ATSAM4SD16C ATSAM4SD32C
Серия: ATSAM4SD32B (10)
ATSAM4SD32BAAU, ATSAM4SD32BA AU
