Datasheet Microchip ATSAM4LS2CA-CFUR — Даташит
Производитель | Microchip |
Серия | ATSAM4LS2C |
Модель | ATSAM4LS2CA-CFUR |
A member of the Microchip's SAM4L family of Flash microcontrollers based on the ARM® Cortex®-M4 processor, the ATSAM4LS2C delivers the lowest power in active mode (90uA/MHz) as well as sleep mode (1.5uA) and the shortest wake-up time (down to 1.5us) in a Cortex-M4 device
Купить ATSAM4LS2CA-CFUR на РадиоЛоцман.Цены — от 336 до 551 ₽ 17 предложений от 13 поставщиков ARM® Cortex®-M4 SAM4L Microcontroller IC 32-Bit Single-Core 48MHz 128KB (128K x 8) FLASH 100-VFBGA (7x7) | |||
ATSAM4LS2CA-CFUR Microchip | 336 ₽ | ||
ATSAM4LS2CA-CFUR Atmel | 409 ₽ | ||
ATSAM4LS2CA-CFUR Microchip | по запросу | ||
Корпус | VFBGA |
Количество выводов | 100 |
# of Comparators | 4 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M4 |
CRC/Scan | Yes |
Cap. Touch Channels | 32 |
Configurable Logic Cell Modules | 2 CLC |
High Voltage Capable | No |
I2C | 4 |
Internal Oscillator | 80Mhz, 2,4,8Mhz , 32Khz, 115Khz |
Math Accelerator | No |
Max 16 Bit Digital Timers | 6 |
Max D/A Resolution | 10 bits |
Max. CPU Speed MHz | 48 |
Number of D/A Converters | 2 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.68 |
Pin count | 100 |
Размер памяти программ | 128 Kbytes |
RAM | 32768 bytes |
SPIв„ў | 1 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 15 |
UART | 4 |
Zero Cross detect | No |
ATSAM4LC2A ATSAM4LC2B ATSAM4LC2C ATSAM4LC4A ATSAM4LC4B ATSAM4LC4C ATSAM4LC8A ATSAM4LC8B ATSAM4LC8C ATSAM4LS2A ATSAM4LS2B ATSAM4LS4A ATSAM4LS4B ATSAM4LS4C ATSAM4LS8A ATSAM4LS8B ATSAM4LS8C
Серия: ATSAM4LS2C (4)
- ATSAM4LS2CA-AU ATSAM4LS2CA-AUR ATSAM4LS2CA-CFU ATSAM4LS2CA-CFUR
ATSAM4LS2CACFUR, ATSAM4LS2CA CFUR
