Datasheet Microchip ATSAM3X8EA-AU — Даташит
Производитель | Microchip |
Серия | ATSAM3X8E |
Модель | ATSAM3X8EA-AU |
Based on the ARM® Cortex®-M3 processor, the Microchip's SAM3X8E runs at 84MHz and features 512KB of flash memory in 2 x 256KB banks and 100KB of SRAM in 64KB +32KB banks, with an additional 4KB as NFC (NAND Flash controller) SRAM
Datasheet SAM3X, SAM3A Series
PDF, 6.1 Мб, Версия: 03-01-2015, Файл закачен: 2 ноя 2017, Страниц: 1459
SMART ARM-based MCU
SMART ARM-based MCU
Купить ATSAM3X8EA-AU на РадиоЛоцман.Цены — от 351 до 3 267 ₽ 44 предложений от 22 поставщиков ARM® Cortex®-M3 SAM3X Microcontroller IC 32-Bit Single-Core 84MHz 512KB (512K x 8) FLASH 144-LQFP (20x20) | |||
ATSAM3X8EA-AU Atmel | 351 ₽ | ||
ATSAM3X8EA-AU Atmel | 369 ₽ | ||
ATSAM3X8EA-AU Microchip | 1 440 ₽ | ||
ATSAM3X8EA-AU Microchip | 1 656 ₽ |
Корпус | LQFP |
Количество выводов | 144 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M3 |
CRC/Scan | No |
Cap. Touch Channels | 32 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 4,8,12Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 84 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 144 |
Размер памяти программ | 512 Kbytes |
RAM | 98304 bytes |
SPIв„ў | 4 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 5 |
Zero Cross detect | No |
ATSAM3A4C ATSAM3A8C ATSAM3X4C ATSAM3X4E ATSAM3X8C
Серия: ATSAM3X8E (2)
- ATSAM3X8EA-AU ATSAM3X8EA-CU
ATSAM3X8EAAU, ATSAM3X8EA AU
