Datasheet Microchip ATSAM3X8CA-CU — Даташит
Производитель | Microchip |
Серия | ATSAM3X8C |
Модель | ATSAM3X8CA-CU |
Based on the ARM® Cortex®-M3 processor, the Microchip's SAM3X8C runs at 84MHz and features 512KB of flash memory in 2 x 256KB banks and 96KB of SRAM in 64KB +32KB banks
Datasheet SAM3X, SAM3A Series
PDF, 6.1 Мб, Версия: 03-01-2015, Файл закачен: 2 ноя 2017, Страниц: 1459
SMART ARM-based MCU
SMART ARM-based MCU
Купить ATSAM3X8CA-CU на РадиоЛоцман.Цены — от 495 до 2 114 ₽ 22 предложений от 14 поставщиков ARM® Cortex®-M3 SAM3X Microcontroller IC 32-Bit Single-Core 84MHz 512KB (512K x 8) FLASH 100-TFBGA (9x9) | |||
ATSAM3X8CA-CU Microchip | 495 ₽ | ||
ATSAM3X8CA-CU Microchip | 761 ₽ | ||
ATSAM3X8CA-CU Microchip | 800 ₽ | ||
ATSAM3X8CA-CU Microchip | 1 915 ₽ |
Корпус | TFBGA |
Количество выводов | 100 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M3 |
CRC/Scan | No |
Cap. Touch Channels | 31 |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 4,8,12Mhz,32Khz |
Math Accelerator | No |
Max # PWM outputs | 4 including complementary outputs |
Max D/A Resolution | 12 bits |
Max. CPU Speed MHz | 84 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 1.62 |
Pin count | 100 |
Размер памяти программ | 512 Kbytes |
RAM | 98304 bytes |
SPIв„ў | 4 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 4 |
Zero Cross detect | No |
ATSAM3A4C ATSAM3A8C ATSAM3X4C ATSAM3X4E ATSAM3X8E
Серия: ATSAM3X8C (2)
- ATSAM3X8CA-AU ATSAM3X8CA-CU
ATSAM3X8CACU, ATSAM3X8CA CU
