Datasheet Linear Technology LTC4364 — Даташит
Серия | LTC4364 |
Surge Stopper with Ideal Diode
Datasheet LTC4364-1, LTC4364-2
PDF, 314 Кб, Язык: анг., Файл закачен: 25 окт 2017, Страниц: 24
Купить LTC4364 на РадиоЛоцман.Цены — от 179 до 548 ₽ 10 предложений от 6 поставщиков Минимально для заказа 7шт. | |||
LTC4364HMS-2 Linear Technology | 179 ₽ | ||
LTC2370CMS-16 LTC3129EMSE LTC3775EMSE LTC2368CMS-24 LTC3607IMSE LTC3646IMSE LTC4364CMS-2 LTC3851AEMSE IC | 378 ₽ | ||
LTC4364CS-1 Analog Devices | 1 028 ₽ | ||
LTC4364HMS-2 PBF Linear Technology | по запросу |
Parameters / Models | LTC4364CDE-1#PBF | LTC4364CDE-1#TRPBF | LTC4364CDE-2#PBF | LTC4364CDE-2#TRPBF | LTC4364CMS-1#PBF | LTC4364CMS-1#TRPBF | LTC4364CMS-2#PBF | LTC4364CMS-2#TRPBF | LTC4364CS-1#PBF | LTC4364CS-1#TRPBF | LTC4364CS-2#PBF | LTC4364CS-2#TRPBF | LTC4364HDE-1#PBF | LTC4364HDE-1#TRPBF | LTC4364HDE-2#PBF | LTC4364HDE-2#TRPBF | LTC4364HMS-1#PBF | LTC4364HMS-1#TRPBF | LTC4364HMS-2#PBF | LTC4364HMS-2#TRPBF | LTC4364HS-1#PBF | LTC4364HS-1#TRPBF | LTC4364HS-2#PBF | LTC4364HS-2#TRPBF | LTC4364IDE-1#PBF | LTC4364IDE-1#TRPBF | LTC4364IDE-2#PBF | LTC4364IDE-2#TRPBF | LTC4364IMS-1#PBF | LTC4364IMS-1#TRPBF | LTC4364IMS-2#PBF | LTC4364IMS-2#TRPBF | LTC4364IS-1#PBF | LTC4364IS-1#TRPBF | LTC4364IS-2#PBF | LTC4364IS-2#TRPBF |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Demo Boards | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B | DC2027A-A,DC2027A-B |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Diode Off with Back-to-Back FETs? | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ideal Diode | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel | Single, External, N-Channel |
Internal FET | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Supply for FET Gate drive | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump | Internal Charge Pump |
Total Quiescent Current, мА | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 | 0.483 |
Typical Current Capability, A | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Vin Max, В | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
Vin Min, В | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
LTC4364CDE-1#PBF | LTC4364CDE-1#TRPBF | LTC4364CDE-2#PBF | LTC4364CDE-2#TRPBF | LTC4364CMS-1#PBF | LTC4364CMS-1#TRPBF | LTC4364CMS-2#PBF | LTC4364CMS-2#TRPBF | LTC4364CS-1#PBF | LTC4364CS-1#TRPBF | LTC4364CS-2#PBF | LTC4364CS-2#TRPBF | LTC4364HDE-1#PBF | LTC4364HDE-1#TRPBF | LTC4364HDE-2#PBF | LTC4364HDE-2#TRPBF | LTC4364HMS-1#PBF | LTC4364HMS-1#TRPBF | LTC4364HMS-2#PBF | LTC4364HMS-2#TRPBF | LTC4364HS-1#PBF | LTC4364HS-1#TRPBF | LTC4364HS-2#PBF | LTC4364HS-2#TRPBF | LTC4364IDE-1#PBF | LTC4364IDE-1#TRPBF | LTC4364IDE-2#PBF | LTC4364IDE-2#TRPBF | LTC4364IMS-1#PBF | LTC4364IMS-1#TRPBF | LTC4364IMS-2#PBF | LTC4364IMS-2#TRPBF | LTC4364IS-1#PBF | LTC4364IS-1#TRPBF | LTC4364IS-2#PBF | LTC4364IS-2#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- Surge Stopper with Ideal Diode Protects Input and Output &mdash LT JournalPDF, 2.6 Мб, Файл опубликован: 18 окт 2012Выписка из документа
Серия: LTC4364 (36)
- LTC4364CDE-1#PBF LTC4364CDE-1#TRPBF LTC4364CDE-2#PBF LTC4364CDE-2#TRPBF LTC4364CMS-1#PBF LTC4364CMS-1#TRPBF LTC4364CMS-2#PBF LTC4364CMS-2#TRPBF LTC4364CS-1#PBF LTC4364CS-1#TRPBF LTC4364CS-2#PBF LTC4364CS-2#TRPBF LTC4364HDE-1#PBF LTC4364HDE-1#TRPBF LTC4364HDE-2#PBF LTC4364HDE-2#TRPBF LTC4364HMS-1#PBF LTC4364HMS-1#TRPBF LTC4364HMS-2#PBF LTC4364HMS-2#TRPBF LTC4364HS-1#PBF LTC4364HS-1#TRPBF LTC4364HS-2#PBF LTC4364HS-2#TRPBF LTC4364IDE-1#PBF LTC4364IDE-1#TRPBF LTC4364IDE-2#PBF LTC4364IDE-2#TRPBF LTC4364IMS-1#PBF LTC4364IMS-1#TRPBF LTC4364IMS-2#PBF LTC4364IMS-2#TRPBF LTC4364IS-1#PBF LTC4364IS-1#TRPBF LTC4364IS-2#PBF LTC4364IS-2#TRPBF
- Monitor, Control and Protection > Surge Stopper, Overvoltage & Overcurrent Protection | PowerPath Controllers & Ideal Diodes
- Monitor, Control and Protection > Hot Swap Controllers > High Voltage Hot Swap Controllers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
