Datasheet Linear Technology LTC2975 — Даташит
Серия | LTC2975 |
4-Channel PMBus Power System Manager Featuring Accurate Input Current and Energy Measurement
LTC2975 - 4-Channel PMBus Power System Manager Featuring Accurate Input Current and Energy Measurement
PDF, 1.3 Мб, Файл закачен: 31 июл 2016
Купить LTC2975 на РадиоЛоцман.Цены — от 847 до 3 623 ₽ 22 предложений от 12 поставщиков Power Supply Controller Power Supply Controller/Monitor 64-QFN (9x9) | |||
LTC2975CUP#PBF Analog Devices | 847 ₽ | ||
LTC2975IUP#PBF Analog Devices | 1 046 ₽ | ||
LTC2975CUP#PBF Analog Devices | от 1 743 ₽ | ||
LTC2975IUP#PBF Analog Devices | по запросу |
LTC2975CUP#PBF | LTC2975CUP#TRPBF | LTC2975IUP#PBF | LTC2975IUP#TRPBF | |
N | 1 | 2 | 3 | 4 |
Корпус | 9x9 QFN-64 Габаритный чертеж корпуса | 9x9 QFN-64 Габаритный чертеж корпуса | 9x9 QFN-64 Габаритный чертеж корпуса | 9x9 QFN-64 Габаритный чертеж корпуса |
Код корпуса | UP | UP | UP | UP |
Индекс корпуса | 05-08-1705 | 05-08-1705 | 05-08-1705 | 05-08-1705 |
Количество выводов | 64 | 64 | 64 | 64 |
Parameters / Models | LTC2975CUP#PBF | LTC2975CUP#TRPBF | LTC2975IUP#PBF | LTC2975IUP#TRPBF |
ADC | 16-Bit | 16-Bit | 16-Bit | 16-Bit |
Demo Boards | DC1508B-B,DC2022A,DC2428A,DC2518A,DC2578A | DC1508B-B,DC2022A,DC2428A,DC2518A,DC2578A | DC1508B-B,DC2022A,DC2428A,DC2518A,DC2578A | DC1508B-B,DC2022A,DC2428A,DC2518A,DC2578A |
Design Tools | LTpowerPlay ,Linduino File | LTpowerPlay ,Linduino File | LTpowerPlay ,Linduino File | LTpowerPlay ,Linduino File |
Экспортный контроль | нет | нет | нет | нет |
Основные особенности | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Input Energy Monitor, Internal Temp Monitor, Voltage Monitor, Current Monitor, Power Monitor, Cascadable | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Input Energy Monitor, Internal Temp Monitor, Voltage Monitor, Current Monitor, Power Monitor, Cascadable | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Input Energy Monitor, Internal Temp Monitor, Voltage Monitor, Current Monitor, Power Monitor, Cascadable | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Input Energy Monitor, Internal Temp Monitor, Voltage Monitor, Current Monitor, Power Monitor, Cascadable |
I/O | PMBus/SMBus/I2C | PMBus/SMBus/I2C | PMBus/SMBus/I2C | PMBus/SMBus/I2C |
Isupply, мА | 10 | 10 | 10 | 10 |
Number of Supplies | 4 | 4 | 4 | 4 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 |
Vin Range | 3.13V to 15V | 3.13V to 15V | 3.13V to 15V | 3.13V to 15V |
RoHS | Совместим | Совместим | Совместим | Совместим |
- Accurate Temperature Sensing with an External P-N Junction &mdash AN137PDF, 540 Кб, Файл опубликован: 20 сен 2012
Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.Выписка из документа - Overview of the EEPROM in LTC PSM Devices &mdash AN145PDF, 3.0 Мб, Файл опубликован: 10 май 2014Выписка из документа
- Power System Management Addressing &mdash AN152PDF, 169 Кб, Файл опубликован: 12 июл 2016Выписка из документа
- Linduino for Power System Management &mdash AN153PDF, 1.3 Мб, Файл опубликован: 24 фев 2016Выписка из документа
- Fault Log Decoding with Linduino PSM &mdash AN155PDF, 230 Кб, Файл опубликован: 26 янв 2017Выписка из документа
- In Flight Update with Linduino &mdash AN166PDF, 1.1 Мб, Файл опубликован: 10 апр 2017Выписка из документа
Серия: LTC2975 (4)
- Monitor, Control and Protection > Power Monitors
- Monitor, Control and Protection > Digital Power System Management > Digital Power System Managers
