Datasheet Linear Technology LTM4675 — Даташит
Серия | LTM4675 |
Dual 9A or Single 18A µModule (Power Module) Regulator with Digital Power System Management
Datasheet LTM4675
PDF, 2.9 Мб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 132
Dual 9A or Single 18A μModule Regulator with Digital Power System Management
Купить LTM4675 на РадиоЛоцман.Цены — от 1 189 до 8 915 ₽ 21 предложений от 11 поставщиков DC DC CNVRTR 0.5-5.5V 0.5-5.5V | |||
LTM4648IV LTM4618IV LTM4676EV LTM4675IY LTM4641MPY LTM4639IY LTM8003HY LTM4637AEV LTM8008HV LTM4649IY IC | 1 189 ₽ | ||
LTM4675EY#PBF Linear Technology | 2 835 ₽ | ||
LTM4675IY#PBF Analog Devices | от 3 870 ₽ | ||
LTM4675EY#PBF Analog Devices | по запросу |
LTM4675EY#PBF | LTM4675IY | LTM4675IY#PBF | |
N | 1 | 2 | 3 |
Корпус | 16mm x 11.9mm x 3.51mm BGA Габаритный чертеж корпуса | 16mm x 11.9mm x 3.51mm BGA Габаритный чертеж корпуса | 16mm x 11.9mm x 3.51mm BGA Габаритный чертеж корпуса |
Код корпуса | BGA | BGA | BGA |
Индекс корпуса | 05-08-1931 | 05-08-1931 | 05-08-1931 |
Количество выводов | 108 | 108 | 108 |
Parameters / Models | LTM4675EY#PBF | LTM4675IY | LTM4675IY#PBF |
ADC | 16-Bit | 16-Bit | 16-Bit |
DAC | 12-Bit | 12-Bit | 12-Bit |
Demo Boards | DC2053A,DC2204B | DC2053A,DC2204B | DC2053A,DC2204B |
Design Tools | LTspice File,LTpowerCAD File,Linduino File | LTspice File,LTpowerCAD File,Linduino File | LTspice File,LTpowerCAD File,Linduino File |
Экспортный контроль | нет | нет | нет |
Основные особенности | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization | PMBus, EEPROM, Fault Logging, Supervisor, Sequencing, Margining, Internal Temp Monitor, Voltage Monitor, Current Monitor, PolyPhase, External Synchronization |
Function | DC/DC uModule Regulator With Power System Management | DC/DC uModule Regulator With Power System Management | DC/DC uModule Regulator With Power System Management |
I/O | PMBus/SMBus/I2C | PMBus/SMBus/I2C | PMBus/SMBus/I2C |
Isupply, мА | 20 | 20 | 20 |
Monitors | Vin, Iin, Vout, Iout, Temperature and Faults | Vin, Iin, Vout, Iout, Temperature and Faults | Vin, Iin, Vout, Iout, Temperature and Faults |
Количество выходов | 2 | 2 | 2 |
Рабочий диапазон температур, °C | от 0 до 85 | от -40 до 85 | от -40 до 85 |
Диапазон напряжения питания | 4.5V to 17V | 4.5V to 17V | 4.5V to 17V |
Vin Max, В | 17 | 17 | 17 |
Vin Min, В | 4.5 | 4.5 | 4.5 |
RoHS | Совместим | Не совместим | Совместим |
- Accurate Temperature Sensing with an External P-N Junction &mdash AN137PDF, 540 Кб, Файл опубликован: 20 сен 2012
Many Linear Technology devices use an external PNP transistor to sense temperature. Common examples are LTC3880, LTC3883 and LTC2974. Accurate temperature sensing depends on proper PNP selection, layout, and device configuration. This application note reviews the theory of temperature sensing and gives practical advice on implementation.Выписка из документа - Overview of the EEPROM in LTC PSM Devices &mdash AN145PDF, 3.0 Мб, Файл опубликован: 10 май 2014Выписка из документа
- Power System Management Addressing &mdash AN152PDF, 169 Кб, Файл опубликован: 12 июл 2016Выписка из документа
- Linduino for Power System Management &mdash AN153PDF, 1.3 Мб, Файл опубликован: 24 фев 2016Выписка из документа
- Fault Log Decoding with Linduino PSM &mdash AN155PDF, 230 Кб, Файл опубликован: 26 янв 2017Выписка из документа
- In Flight Update with Linduino &mdash AN166PDF, 1.1 Мб, Файл опубликован: 10 апр 2017Выписка из документа
- Implementing Fast Telemetry with Power System Management Controllers &mdash AN168PDF, 165 Кб, Файл опубликован: 8 фев 2018Выписка из документа
Design Notes
- Dual 9A, Step-Down ОјModule Regulator with Digital Power System Management &mdash DN542PDF, 342 Кб, Файл опубликован: 16 июл 2015Выписка из документа
Серия: LTM4675 (3)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- Power Management > Switching Regulator > Digitally Programmable Regulators
- µModule Solutions > µModule Regulators > µModule Buck Regulators
- Monitor, Control and Protection > Digital Power System Management > DC/DC uModule With Power System Management
