Datasheet Linear Technology LT1510 — Даташит
Серия | LT1510 |
Constant-Voltage/Constant-Current Battery Charger
Datasheet LT1510, LT1510-5
PDF, 297 Кб, Язык: анг., Файл закачен: 2 окт 2017, Страниц: 16
Купить LT1510 на РадиоЛоцман.Цены — от 202 до 123 057 ₽ 35 предложений от 25 поставщиков Battery Charger Li-Ion/NiCD/NiMH 1500mA 2V to 20V 8Pin SOIC N | |||
LT1510-5CGN#TRPBF Analog Devices | от 202 ₽ | ||
Бесплатная доставка LT1510 LT1510CS8 SOP8 | 217 ₽ | ||
LT1510-5CGN Linear Technology | по запросу | ||
LT1510CS& | по запросу |
Parameters / Models | LT1510-5CGN#PBF | LT1510-5CGN#TRPBF | LT1510-5IGN#PBF | LT1510-5IGN#TRPBF | LT1510CGN#PBF | LT1510CGN#TRPBF | LT1510CN#PBF | LT1510CS#PBF | LT1510CS#TRPBF | LT1510CS8#PBF | LT1510CS8#TRPBF | LT1510IGN#PBF | LT1510IGN#TRPBF | LT1510IN#PBF | LT1510IS#PBF | LT1510IS#TRPBF | LT1510IS8#PBF | LT1510IS8#TRPBF |
Battery Chemistry | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid | Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid |
Charge Termination | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 | Use LTC1729 |
Demo Boards | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D | DC086A,DC179A,DC294A-B,DC294A-D |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Float Voltage, В | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj |
Internal Pass Element | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Max Charge Current, A | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Number of Cells | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) | 1 to 4 (Li), 1 to 12 (Ni) |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Type of Charger | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching | Switching |
Vin Max, В | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 | 29 |
Vin Min, В | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
LT1510-5CGN#PBF | LT1510-5CGN#TRPBF | LT1510-5IGN#PBF | LT1510-5IGN#TRPBF | LT1510CGN#PBF | LT1510CGN#TRPBF | LT1510CN#PBF | LT1510CS#PBF | LT1510CS#TRPBF | LT1510CS8#PBF | LT1510CS8#TRPBF | LT1510IGN#PBF | LT1510IGN#TRPBF | LT1510IN#PBF | LT1510IS#PBF | LT1510IS#TRPBF | LT1510IS8#PBF | LT1510IS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
- Linear Technology Magazine Circuit Collection, Volume III &mdash AN67PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.Выписка из документа - LT1510 Design Manual &mdash AN68PDF, 377 Кб, Файл опубликован: 30 дек 1996
The ever-growing popularity of portable equipment in recent years has pushed battery technologists to search for battery types that store more energy in a smaller volume, weigh less and are safer. Also, the power source selection for charging the batteries has diversified. For example, a notebook computer can be connected to a car battery, a power adapter, a docking station or even to solar cells. The variety of input voltages, coupled with the need for high efficiency and the need for accurate constant voltage and constant current, as in the case of Li-Ion batteries (see below), have led to the introduction of a switching type constant-voltage, constant-current battery charger IC, the LT®1510.Выписка из документа
Design Notes
- LT1510 High Efficiency Lithium-Ion Battery Charger &mdash DN111PDF, 77 Кб, Файл опубликован: 1 сен 1995Выписка из документа
- New Battery Charger ICs Need No Heat Sinks &mdash DN124PDF, 75 Кб, Файл опубликован: 1 мар 1996Выписка из документа
- Inexpensive Circuit Charges Lithium-Ion Cells &mdash DN188PDF, 72 Кб, Файл опубликован: 1 сен 1998Выписка из документа
- Li-Ion Charge Termination IC Interfaces with PWM Switchers &mdash DN242PDF, 74 Кб, Файл опубликован: 2 окт 2001Выписка из документа
Серия: LT1510 (18)
- Power Management > Battery Management > Battery Charger IC > Switching Battery Chargers
