Datasheet Texas Instruments AMC1303M2510DWV — Даташит
Серия | AMC1303M2510 |
Модель | AMC1303M2510DWV |
Small Reinforced Isolated Modulator With В±250mV Input, Internal Clock, and CMOS Interface 8-SOIC -40 to 125
AMC1303x Small, High-Precision, Reinforced Isolated Delta-Sigma Modulators With Internal Clock datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 25 июл 2017
Купить AMC1303M2510DWV на РадиоЛоцман.Цены — от 429 до 36 278 ₽ 16 предложений от 9 поставщиков TEXAS INSTRUMENTS - AMC1303M2510DWV - ADC, DELTA-SIGMA, 16BIT, 10MSPS, SOIC-8 | |||
AMC1303M2510DWV Texas Instruments | от 429 ₽ | ||
AMC1303M2510DWV Texas Instruments | 635 ₽ | ||
AMC1303M2510DWV Texas Instruments | 782 ₽ | ||
AMC1303M2510DWV Texas Instruments | по запросу |
Pin | 8 |
Package Type | DWV |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 64 |
Carrier | TUBE |
Маркировка | 1303M251 |
Width (мм) | 7.5 |
Length (мм) | 5.85 |
Thickness (мм) | 2.65 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.8 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 3 В |
Архитектура | Delta-Sigma |
CMTI(Min) | 50 kV/µs |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 2.7 В |
INL(Max) | 4 +/-LSB |
Input Range | 250mV Vp-p |
Interface | Serial CMOS |
Isolation | 7 kV peak |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 67 mm2: 11.5 x 5.85(SOIC) PKG |
Power Consumption(Typ) | 29.4 mW |
Rating | Catalog |
SFDR | 98 дБ |
SNR | 85 дБ |
Sample Rate (max) | 10MSPS SPS |
Sample Rate(Max) | 10 MSPS |
THD(Max) | -86 дБ |
- Evaluation Modules & Boards: AMC1303EVM
AMC1303 Evaluation Module
Серия: AMC1303M2510 (2)
- AMC1303M2510DWV AMC1303M2510DWVR
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > Isolated ADCs
