Datasheet Texas Instruments AMC1303E2520DWVR — Даташит
Серия | AMC1303E2520 |
Модель | AMC1303E2520DWVR |
Small Reinforced Isolated Modulator w/ В±250mV Input, Int Clk, and Manchester-Encoded CMOS Interface 8-SOIC -40 to 125
AMC1303x Small, High-Precision, Reinforced Isolated Delta-Sigma Modulators With Internal Clock datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 25 июл 2017
Купить AMC1303E2520DWVR на РадиоЛоцман.Цены — от 643 до 25 017 ₽ 11 предложений от 8 поставщиков Single Channel Single ADC Delta-Sigma 20MSPS 16Bit Serial CMOS 8Pin SOIC T/R | |||
AMC1303E2520DWVR Texas Instruments | 643 ₽ | ||
AMC1303E2520DWVR Texas Instruments | 676 ₽ | ||
AMC1303E2520DWVR | 25 017 ₽ | ||
AMC1303E2520DWVR Texas Instruments | по запросу |
Pin | 8 |
Package Type | DWV |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | 1303E252 |
Width (мм) | 7.5 |
Length (мм) | 5.85 |
Thickness (мм) | 2.65 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.8 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 3 В |
Архитектура | Delta-Sigma |
CMTI(Min) | 50 kV/µs |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 2.7 В |
INL(Max) | 4 +/-LSB |
Input Range | 250mV Vp-p |
Interface | Serial CMOS |
Isolation | 7 kV peak |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 67 mm2: 11.5 x 5.85(SOIC) PKG |
Power Consumption(Typ) | 34.3 mW |
Rating | Catalog |
SFDR | 100 дБ |
SNR | 84.5 дБ |
Sample Rate (max) | 20MSPS SPS |
Sample Rate(Max) | 20 MSPS |
THD(Max) | -86 дБ |
- Evaluation Modules & Boards: AMC1303EVM
AMC1303 Evaluation Module
Серия: AMC1303E2520 (2)
- AMC1303E2520DWV AMC1303E2520DWVR
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > Isolated ADCs
