Datasheet Microchip ATMEGA1284P-PU — Даташит
Производитель | Microchip |
Серия | ATmega1284P |
Модель | ATMEGA1284P-PU |
The high-performance Microchip 8-bit AVR RISC-based microcontroller combines 128KB ISP flash memory with read-while-write capabilities, 4KB EEPROM, 16KB SRAM, 32 general purpose I/O lines, 32 general purpose working registers, a real time counter, three flexible timer/counters with compare modes and PWM, two USARTs, a byte oriented 2-wire serial interface, an 8-channel 10-bit A/D converter with optional differential input stage with programmable gain, programmable watchdog timer with internal oscillator, SPI serial port, a JTAG (IEEE 1149
Datasheet ATmega1284P - Complete
PDF, 5.9 Мб, Файл опубликован: 10 дек 2016, Страниц: 461
8-bit AVR Microcontrollers
ATmega1284P - Summary Datasheet
PDF, 409 Кб, Файл опубликован: 10 дек 2016
Купить ATMEGA1284P-PU на РадиоЛоцман.Цены — от 1 042 до 1 990 ₽ 50 предложений от 24 поставщиков 8 Bit MCU, AVR ATmega Family ATmega128 Series Microcontrollers, 20 МГц, 128 КБ, 16 КБ | |||
ATMEGA1284P-PU Microchip | от 1 042 ₽ | ||
ATMEGA164A-PU ATMEGA164PA-PU ATMEGA164P-20PU ATMEGA164PV-10PU ATMEGA1284P-PU ATMEGA8515-16PU ATMEGA8515L-8PU ATMEGA8535-16PU IC MCU DIP-40 | 270 ₽ | ||
ATMEGA1284P-PU Atmel | 458 ₽ | ||
ATMEGA1284P-PU Microchip | по запросу |
Корпус | PDIP |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
Emulated EEPROM in Flash | 4096 |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 40 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 2 |
Max 8-Bit Digital Timers | 2 |
Max CPU Speed | 20 МГц |
Max PWM outputs | 6 including complementary |
Количество компараторов | 1 |
Package Width | .600in |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 44 |
Размер памяти программ | 128 KB |
SPI | 3 |
SRAM | 16384 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
UART | 2 |
Zero Cross detect | No |
Серия: ATmega1284P (5)
- ATMEGA1284P-AU ATMEGA1284P-AUR ATMEGA1284P-MU ATMEGA1284P-MUR ATMEGA1284P-PU
- Microcontrollers > 8-bit Microcontrollers
ATMEGA1284PPU, ATMEGA1284P PU
