Datasheet Linear Technology LTC3265 — Даташит
Серия | LTC3265 |
Low Noise Dual Supply with Boost and Inverting Charge Pumps
LTC3265 - Low Noise Dual Supply with Boost and Inverting Charge Pumps
PDF, 759 Кб, Версия: A, Файл закачен: 27 сен 2017
Купить LTC3265 на РадиоЛоцман.Цены — от 333 до 1 683 ₽ 24 предложений от 12 поставщиков Charge Pump Switching Regulator IC Positive and Negative (Dual Rail) Fixed -Vin, 2Vin 2 Output 100mA 18-WFDFN Exposed Pad | |||
LTC3265EFE#PBF Analog Devices | 333 ₽ | ||
LT1794CFE LT1970IFE LT3475EFE LT1739IFE LT3501EFE LT1795IFE LT8711EFE LTC3265EFE LTC4011CFE IC | 378 ₽ | ||
LTC3265EFE#TRPBF Analog Devices | от 843 ₽ | ||
LTC3265MPFE#TRPBF Analog Devices | по запросу |
Parameters / Models | LTC3265EDHC#PBF | LTC3265EDHC#TRPBF | LTC3265EFE#PBF | LTC3265EFE#TRPBF | LTC3265HDHC#PBF | LTC3265HDHC#TRPBF | LTC3265HFE#PBF | LTC3265HFE#TRPBF | LTC3265IDHC#PBF | LTC3265IDHC#TRPBF | LTC3265IFE#PBF | LTC3265IFE#TRPBF | LTC3265MPDHC#PBF | LTC3265MPDHC#TRPBF | LTC3265MPFE#PBF | LTC3265MPFE#TRPBF |
Demo Boards | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A | DC2235A |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Тактовая частота, kHz | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 |
Function | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump | Regulated Step-Up Charge Pump, Regulated Inverting Charge Pump |
Ishutdown, мкА | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Isupply, мА | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 | 0.085 |
Количество выходов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Выходной ток, A | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Выходное напряжение | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj | Adj |
Vin Max, В | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 |
Vin Min, В | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
LTC3265EDHC#PBF | LTC3265EDHC#TRPBF | LTC3265EFE#PBF | LTC3265EFE#TRPBF | LTC3265HDHC#PBF | LTC3265HDHC#TRPBF | LTC3265HFE#PBF | LTC3265HFE#TRPBF | LTC3265IDHC#PBF | LTC3265IDHC#TRPBF | LTC3265IFE#PBF | LTC3265IFE#TRPBF | LTC3265MPDHC#PBF | LTC3265MPDHC#TRPBF | LTC3265MPFE#PBF | LTC3265MPFE#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC3265 (16)
- Power Management > Inductorless (Charge Pump) DC/DC Converters > Regulated Step-Up Charge Pumps | Regulated Inverting Charge Pumps
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
