Datasheet Linear Technology LTC1682 — Даташит
Серия | LTC1682 |
Doubler Charge Pumps with Low Noise Linear Regulator
LTC1682/LTC1682-3.3/LTC1682-5 - Doubler Charge Pumps with Low Noise Linear Regulator
PDF, 201 Кб, Версия: S, Файл закачен: 27 сен 2017
Купить LTC1682 на РадиоЛоцман.Цены — от 131 до 730 ₽ 20 предложений от 19 поставщиков Doubler Charge Pumps with Low Noise Linear Regulator | |||
LTC1682CS8 Analog Devices | 131 ₽ | ||
LTC1682CS8-3.3 Linear Technology | 150 ₽ | ||
LTC1682IMS8-5 | 600 ₽ | ||
LTC1682CS8-5 Analog Devices | по запросу |
Parameters / Models | LTC1682CMS8#PBF | LTC1682CMS8#TRPBF | LTC1682CMS8-3.3#PBF | LTC1682CMS8-3.3#TRPBF | LTC1682CMS8-5#PBF | LTC1682CMS8-5#TRPBF | LTC1682CS8#PBF | LTC1682CS8#TRPBF | LTC1682CS8-3.3#PBF | LTC1682CS8-3.3#TRPBF | LTC1682CS8-5#PBF | LTC1682CS8-5#TRPBF | LTC1682IMS8#PBF | LTC1682IMS8#TRPBF | LTC1682IMS8-3.3#PBF | LTC1682IMS8-3.3#TRPBF | LTC1682IMS8-5#PBF | LTC1682IMS8-5#TRPBF | LTC1682IS8#PBF | LTC1682IS8#TRPBF | LTC1682IS8-3.3#PBF | LTC1682IS8-3.3#TRPBF | LTC1682IS8-5#PBF | LTC1682IS8-5#TRPBF |
Demo Boards | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A | DC249A-A,DC249A-B,DC249A-C,DC332A |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Тактовая частота, kHz | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 |
Function | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump | Regulated Step-Up Charge Pump |
Ishutdown, мкА | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Isupply, мА | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Выходное напряжение | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj | 3.3V, 5V, Adj |
Vin Max, В | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 | 4.4 |
Vin Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
LTC1682CMS8#PBF | LTC1682CMS8#TRPBF | LTC1682CMS8-3.3#PBF | LTC1682CMS8-3.3#TRPBF | LTC1682CMS8-5#PBF | LTC1682CMS8-5#TRPBF | LTC1682CS8#PBF | LTC1682CS8#TRPBF | LTC1682CS8-3.3#PBF | LTC1682CS8-3.3#TRPBF | LTC1682CS8-5#PBF | LTC1682CS8-5#TRPBF | LTC1682IMS8#PBF | LTC1682IMS8#TRPBF | LTC1682IMS8-3.3#PBF | LTC1682IMS8-3.3#TRPBF | LTC1682IMS8-5#PBF | LTC1682IMS8-5#TRPBF | LTC1682IS8#PBF | LTC1682IS8#TRPBF | LTC1682IS8-3.3#PBF | LTC1682IS8-3.3#TRPBF | LTC1682IS8-5#PBF | LTC1682IS8-5#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- Tiny Regulators Drive White LED Backlights &mdash DN231PDF, 76 Кб, Файл опубликован: 1 май 2001Выписка из документа
Статьи
- Low Noise Boost VCO Power Supply for Portable Applications &mdash LT JournalPDF, 167 Кб, Файл опубликован: 1 сен 1999Выписка из документа
Серия: LTC1682 (24)
- LTC1682CMS8#PBF LTC1682CMS8#TRPBF LTC1682CMS8-3.3#PBF LTC1682CMS8-3.3#TRPBF LTC1682CMS8-5#PBF LTC1682CMS8-5#TRPBF LTC1682CS8#PBF LTC1682CS8#TRPBF LTC1682CS8-3.3#PBF LTC1682CS8-3.3#TRPBF LTC1682CS8-5#PBF LTC1682CS8-5#TRPBF LTC1682IMS8#PBF LTC1682IMS8#TRPBF LTC1682IMS8-3.3#PBF LTC1682IMS8-3.3#TRPBF LTC1682IMS8-5#PBF LTC1682IMS8-5#TRPBF LTC1682IS8#PBF LTC1682IS8#TRPBF LTC1682IS8-3.3#PBF LTC1682IS8-3.3#TRPBF LTC1682IS8-5#PBF LTC1682IS8-5#TRPBF
- Power Management > Inductorless (Charge Pump) DC/DC Converters > Regulated Step-Up Charge Pumps
