Datasheet Linear Technology LT1054CSW#PBF — Даташит
Серия | LT1054 |
Модель | LT1054CSW#PBF |
Switched-Capacitor Voltage Converter with Regulator
LT1054/LT1054L - Switched-Capacitor Voltage Converter with Regulator
PDF, 296 Кб, Версия: H, Файл закачен: 27 сен 2017
Купить LT1054CSW#PBF на РадиоЛоцман.Цены — от 82 до 1 665 ₽ 33 предложений от 21 поставщиков Charge Pump Switching Regulator IC Positive or Negative Adjustable (Fixed) 2.5V (-Vin, 2Vin) 1 Output 100mA 16-SOIC (0.295, 7.50mm Width) | |||
LT1054CSW Linear Technology | 82 ₽ | ||
LT1054CSW#PBF Analog Devices | 234 ₽ | ||
LT1054CSW Linear Technology | 271 ₽ | ||
LT1054CSW#TRPBF Linear Technology | по запросу |
Корпус | SW-16 |
Код корпуса | SW |
Индекс корпуса | 05-08-1620 (SW16) |
Design Tools | LTspice File |
Экспортный контроль | нет |
Тактовая частота | 25 kHz |
Function | Unregulated Doubling/Inverting Charge Pump |
Ishutdown | 1 мкА |
Isupply | 2.5 мА |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 70 °C |
Выходной ток | 0.1 A |
Выходное напряжение | Adj |
Vin Max | 15 В |
Vin Min | 3.5 В |
- Micropower Circuits for Signal Conditioning &mdash AN23PDF, 2.2 Мб, Файл опубликован: 1 апр 1987
Low power operation of electronic apparatus has become increasingly desirable. AN23 describes a variety of low power circuits for transducer signal conditioning. Also included are designs for data converters and switching regulators. Three appended sections discuss guidelines for micropower design, strobed power operation and effects of test equipment on micropower circuits.Выписка из документа - Some Thoughts on DC-DC Converters &mdash AN29PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.Выписка из документа - Switching Regulator Circuit Collection &mdash AN30PDF, 606 Кб, Файл опубликован: 1 фев 1989
Switching regulators are of universal interest. Linear Technology has made a major effort to address this topic. A catalog of circuits has been compiled so that a design engineer can swiftly determine which converter type is best. This catalog serves as a visual index to be browsed through for a specific or general interest.Выписка из документа - A Monolithic Switching Regulator with 100ВµV Output Noise &mdash AN70PDF, 1.7 Мб, Язык: анг., Файл опубликован: 1 окт 1997
This publication details circuitry and applications considerations for the LT1533 low noise switching regulator. Eleven DC/DC converter circuits are presented, some offering <100µV output noise in a 100MHz bandwidth. Tutorial sections detail low noise DC/DC design, measurement, probing and layout techniques, and magnetics selection.Выписка из документа - Current Sources for Fiber Optic Lasers: A Compendium of Pleasant Current Events &mdash AN90PDF, 409 Кб, Файл опубликован: 1 апр 2002
A large group of fiber optic lasers are powered by DC current. Laser drive is supplied by a current source with modulation added to the signal. The current source, although conceptually simple, constitutes an extraordinarily tricky design problem. There are a number of practical requirements for a fiber optic current source and failure to consider them can cause laser and/or optical component destruction. This application note describes ten laser current source circuits with a range of capabilities. High and low current types are presented, along with designs for grounded anode, cathode or floating operation. Each circuit also includes laser protection features. Appended sections cover laser load simulation and current source noise measurement techniques.Выписка из документа
Статьи
- Switched Capacitor Voltage Regulator Provides Current Gain &mdash LT JournalPDF, 44 Кб, Файл опубликован: 1 фев 1999Выписка из документа
Серия: LT1054 (10)
- Power Management > Inductorless (Charge Pump) DC/DC Converters > Unregulated Doubling/Inverting Charge Pumps | Regulated Step-Up Charge Pumps
- Space & Harsh Environment > Military Hermetic (M)
LT1054CSWPBF, LT1054CSW PBF
