Datasheet Linear Technology LTM4651IY#PBF — Даташит
Серия | LTM4651 |
Модель | LTM4651IY#PBF |
EN55022B Compliant 58V, 24W Inverting-Output DC/DC µModule Regulator
LTM4651 - EN55022B Compliant 58V, 24W Inverting-Output DC/DC µModule Regulator
PDF, 1.4 Мб, Файл закачен: 25 сен 2017
Купить LTM4651IY#PBF на РадиоЛоцман.Цены — от 713 до 6 235 ₽ 19 предложений от 9 поставщиков DC DC CNVRTR -0.5 TO -26.5V 24W | |||
LTM4651IY LTM4645IY LTM4661IY LTM4606MPV LTM4622EV | 713 ₽ | ||
LTM4651IY#PBF Analog Devices | 2 082 ₽ | ||
LTM4651IY#PBF Analog Devices | 2 111 ₽ | ||
LTM4651IY#PBF Analog Devices | от 2 456 ₽ |
Корпус | 15mm × 9mm × 5.01mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1826 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC2328A |
Design Tools | LTspice Model,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Low EMI, EN55022 Class B Certified, PolyPhase, Resistor Set Frequency, External Synchronization, Power Good |
Тактовая частота | 3000 kHz |
Frequency Adjust Range | 250kHz - 3MHz |
Frequency Sync Range | 250kHz - 3MHz |
Integrated Inductor | да |
Ishutdown | 16 мкА |
Isupply | 0.45 мА |
Max Phases | 2 |
Monolithic | да |
Количество выходов | 1 |
Polyphase | да |
Switch Current | 20 A |
Synchronous | да |
Topology | Inverting |
Vin Max | 58 В |
Vin Min | 3.6 В |
Vout Max | 26.5 В |
Vref Accuracy Over Temp | 1.67 % |
Vswitch Max | 58 В |
Серия: LTM4651 (3)
- LTM4651EY#PBF LTM4651IY LTM4651IY#PBF
- Power Management > Switching Regulator > Inverting Regulators | Ultralow Noise Regulators
- µModule Solutions > µModule Regulators > µModule Boost, Sepic, & Inverting Regulators
LTM4651IYPBF, LTM4651IY PBF
