Datasheet Linear Technology LTM4630IY-1A#PBF — Даташит
Серия | LTM4630-1 |
Модель | LTM4630IY-1A#PBF |
Dual 18A or Single 36A µModule (Power Module) Regulator with 0.8% DC and 3% Transient Accuracy
Datasheet LTM4630-1
PDF, 1.3 Мб, Язык: анг., Файл закачен: 25 сен 2017, Страниц: 38
Dual 18A or Single 36A μModule (Power Module) Regulator with 0.8% DC and 3% Transient Accuracy
Купить LTM4630IY-1A#PBF на РадиоЛоцман.Цены — от 6 617 до 17 177 ₽ 16 предложений от 7 поставщиков DC DC CNVRTR 0.6-1.8V 0.6-1.8V | |||
LTM4630IY-1A Linear Technology | 6 617 ₽ | ||
LTM4630IY-1A Analog Devices | от 7 310 ₽ | ||
LTM4630IY-1A Analog Devices | от 17 177 ₽ |
Корпус | 16mm x 16mm x 5.01mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1969 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC2081A-B,DC2157A,DC2268A-E,DC2164A-A,DC2164A-B,DC2164A-C |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Differential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Temperature Monitor, Burst Mode, Tracking, Power Good |
Тактовая частота | 500 kHz |
Frequency Adjust Range | 400kHz to 780kHz |
Frequency Sync Range | 400kHz to 780kHz |
Integrated Inductor | да |
Ishutdown | 50 мкА |
Isupply | 3 мА |
Max Phases | 8 |
Monolithic | да |
Количество выходов | 2 |
Выходной ток | 18 A |
Output Current 2 | 18 A |
Polyphase | да |
Switch Current | 25 A |
Switch Current 2 | 25 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Topology 2 | Buck |
Vin Max | 15 В |
Vin Min | 4.5 В |
Vout Max | 1.8 В |
Vout Max 2 | 1.8 В |
Vout Maximum | 1.8V |
Vout Min | 0.6 В |
Vout Min 2 | 0.6 В |
Vref Accuracy Over Temp | 0.8 % |
Серия: LTM4630-1 (6)
- LTM4630EY-1A#PBF LTM4630EY-1B#PBF LTM4630IY-1A LTM4630IY-1A#PBF LTM4630IY-1B LTM4630IY-1B#PBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck
- µModule Solutions > µModule Regulators > µModule Buck Regulators
LTM4630IY-1APBF, LTM4630IY-1A PBF, LTM4630IY1A#PBF, LTM4630IY 1A#PBF
