Datasheet Linear Technology LTM4601EY-1#PBF — Даташит
Серия | LTM4601-1 |
Модель | LTM4601EY-1#PBF |
12A µModule (Power Module) Regulator with PLL, Output Tracking and Margining
Datasheet LTM4601, LTM4601-1
PDF, 964 Кб, Язык: анг., Файл закачен: 24 сен 2017, Страниц: 30
12A µModule Regulator with PLL, Output Tracking and Margining
Купить LTM4601EY-1#PBF на РадиоЛоцман.Цены — от 1 621 до 6 575 ₽ 11 предложений от 7 поставщиков DC DC CONVERTER 0.6-5V | |||
LTM8046MPV LTM8052AEV LTM4612HVIV LTM4612MPV LTM4601EY-1 LTM4601HVEV LTM4649EY LTM8001MPY LTM8026IV LTM4602HVIV IC | 1 621 ₽ | ||
LTM4601EY-1#PBF Analog Devices | 2 195 ₽ | ||
LTM4601EY-1#PBF Analog Devices | по запросу | ||
Корпус | 15mm × 15mm × 3.42mm BGA |
Код корпуса | BGA |
Индекс корпуса | 05-08-1903 |
Архитектура | Constant On-Time Current Mode |
Demo Boards | DC1041A-A,DC1043A-A,DC1043A-B,DC1043A-C,DC1118A-A,DC1118A-B,DC1118A-C |
Design Tools | LTspice File,LTpowerCAD Model |
Экспортный контроль | нет |
Основные особенности | Tracking, Margining, External Synchronization, PolyPhase, Differential Remote Sense, Power Good |
Тактовая частота | 850 kHz |
Frequency Sync Range | 600kHz - 1.1MHz |
Integrated Inductor | да |
Ishutdown | 22 мкА |
Isupply | 3.8 мА |
Max Phases | 4 |
Monolithic | да |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 85 °C |
Выходной ток | 12 A |
Polyphase | да |
Switch Current | 12 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Vin Max | 20 В |
Vin Min | 4.5 В |
Vout Max | 5 В |
Vout Maximum | 5V |
Vout Min | 0.6 В |
- LTM4601 DC/DC uModule Thermal Performance &mdash AN110PDF, 193 Кб, Файл опубликован: 10 май 2007
This application note provides an extensive guideline for the thermal performance of the LTM4601 μModule. The LTM4601 is characterized with and without heatsinking over an extended operating temperature range. De-rating curves are derived with the different heatsinking types, and the equivalent θJA (thermal resistance) is derived. The different θJA parameters are tabulated with reference to the different test conditions.Выписка из документа - Powering Complex FPGA-Based Systems Using Highly Integrated DC/DC uModule Regulator Systems &mdash AN119APDF, 512 Кб, Файл опубликован: 30 апр 2008
In a recent discussion with a system designer, the re- quirement for his power supply was to regulate 1.5V and deliver up to 40A of current to a load that consisted of four FPGAs. This is up to 60W of power that must be delivered in a small area with the lowest proп¬Ѓle (height) possible to allow a steady flow of air for cooling. The power supply had to be surface mountable and operate at high enough efп¬Ѓciency to minimize heat dissipation. He also demanded the simplest possible solution so his time could be dedicated to the more complex tasks. Aside from precise electrical performance, this solution had to remove the heat generated during DC to DC conversion quickly so that the circuit and the ICs in the vicinity do not over heat.Выписка из документа - Powering Complex FPGA-Based Systems Using Highly Integrated DC/DC uModule Regulator Systems &mdash AN119BPDF, 290 Кб, Файл опубликован: 30 апр 2008
In part one of this article, we discussed the circuit and electrical performance of a compact and low proп¬Ѓle 48A, 1.5V DC/DC regulator solution for a four-FPGA design. The new approach uses four DC/DC μModule™ regulators in parallel (Figure 1) to increase output current while sharing the current equally among each device. This solution relies on the accurate current sharing of these μModule regulators to prevent hot-spots by dissipating the heat evenly over a compact surface area. Each DC/DC μModule is a complete power supply with on-board inductor, DC/DC controller, MOSFETs, compensation circuitry and input/output bypass capacitors. It occupies only 15mm × 15mm of board area and has a low proп¬Ѓle (height) of only 2.8mm. This low proп¬Ѓle allows air to flow smoothly over the entire circuit. Moreover, this solution casts no thermal shadow on its surrounding components, further assisting in optimizing thermal performance of the entire system.Выписка из документа
Design Notes
- Simple and Compact 4-Output Point-of-Load DC/DC uModule System &mdash DN411PDF, 705 Кб, Файл опубликован: 21 мар 2007Выписка из документа
Статьи
- Easy High Density Power: 48A Surface Mount DC/DC Power Supply Uses Four Parallel 12A uModule Regulators &mdash LT JournalPDF, 1.1 Мб, Файл опубликован: 14 янв 2008Выписка из документа
Серия: LTM4601-1 (5)
- LTM4601EV-1#PBF LTM4601EY-1#PBF LTM4601IV-1#PBF LTM4601IY-1 LTM4601IY-1#PBF
- µModule Solutions > µModule Regulators > µModule Buck Regulators
LTM4601EY-1PBF, LTM4601EY-1 PBF, LTM4601EY1#PBF, LTM4601EY 1#PBF
