Datasheet Linear Technology LTC3890-2 — Даташит
СерияLTC3890-2
60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC/DC Controller
LTC3890-2: 60V Low IQ, Dual, 2-Phase Synchronous Step-Down DC/DC Controller Data Sheet
PDF, 427 Кб, Файл закачен: 24 сен 2017
LTC3890-2: 5-35Vin 12Vout@2A & 3.3Vout@10A
Электромеханические реле Hongfa – надежность и качество 19 января 2023
LTC3890EUH-2#PBFLTC3890EUH-2#TRPBFLTC3890HUH-2#PBFLTC3890HUH-2#TRPBFLTC3890IUH-2#PBFLTC3890IUH-2#TRPBFLTC3890MPUH-2#PBFLTC3890MPUH-2#TRPBF
N12345678
Корпус5x5 QFN-32
Габаритный чертеж корпуса
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
Код корпусаUHUHUHUHUHUHUHUH
Индекс корпуса05-08-169305-08-169305-08-169305-08-169305-08-169305-08-169305-08-169305-08-1693
Количество выводов3232323232323232
Parameters / ModelsLTC3890EUH-2#PBFLTC3890EUH-2#TRPBFLTC3890HUH-2#PBFLTC3890HUH-2#TRPBFLTC3890IUH-2#PBFLTC3890IUH-2#TRPBFLTC3890MPUH-2#PBFLTC3890MPUH-2#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC2236A-ADC2236A-ADC2236A-ADC2236A-ADC2236A-ADC2236A-ADC2236A-ADC2236A-A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power GoodDCR Current Sense, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good
Тактовая частота, kHz900900900900900900900900
Frequency Adjust Range50kHz - 900kHz50kHz - 900kHz50kHz - 900kHz50kHz - 900kHz50kHz - 900kHz50kHz - 900kHz50kHz - 900kHz50kHz - 900kHz
Frequency Sync Range75kHz - 850kHz75kHz - 850kHz75kHz - 850kHz75kHz - 850kHz75kHz - 850kHz75kHz - 850kHz75kHz - 850kHz75kHz - 850kHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА1414141414141414
Isupply, мА0.0500.0500.0500.0500.0500.0500.0500.050
Max Phases22222222
Monolithicнетнетнетнетнетнетнетнет
Количество выходов22222222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Выходной ток, A1515151515151515
Output Current 2, A1515151515151515
Polyphaseнетнетнетнетнетнетнетнет
Sense ResistorRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCR
Switch Current, A1515151515151515
Switch Current 2, A1515151515151515
Synchronousдададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuckBuck
Topology 2BuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В6060606060606060
Vin Min, В44444444
Vout Max, В2424242424242424
Vout Maximum24V24V24V24V24V24V24V24V
Vout Min, В0.80.80.80.80.80.80.80.8
Vout Min 2, В0.80.80.80.80.80.80.80.8
Vref Accuracy Over Temp, %1.51.51.51.51.51.51.51.5
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Micropower Buck Regulators | High Input Voltage Buck | External Power Switch Buck Controllers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LTC3890-2
