Datasheet Linear Technology LTC3864 — Даташит
Серия | LTC3864 |
60V Low IQ Step-Down DC/DC Controller with 100% Duty Cycle Capability
Datasheet LTC3864
PDF, 709 Кб, Язык: анг., Файл закачен: 24 сен 2017, Страниц: 30
Купить LTC3864 на РадиоЛоцман.Цены — от 180 до 900 ₽ 34 предложений от 23 поставщиков Low IQ High Voltage Non-Synchronous P-Channel Step-Down DC/DC Controller with 100% Duty Cycle | |||
LTC3864EDE#PBF Analog Devices | 180 ₽ | ||
LTC3864EMSE#PBF Analog Devices | 193 ₽ | ||
LTC3864EMSE#PBF | 228 ₽ | ||
LTC3864EMSE Linear Technology | от 330 ₽ |
Parameters / Models | LTC3864EDE#PBF | LTC3864EDE#TRPBF | LTC3864EMSE#PBF | LTC3864EMSE#TRPBF | LTC3864HDE#PBF | LTC3864HDE#TRPBF | LTC3864HMSE#PBF | LTC3864HMSE#TRPBF | LTC3864IDE#PBF | LTC3864IDE#TRPBF | LTC3864IMSE#PBF | LTC3864IMSE#TRPBF | LTC3864MPDE#PBF | LTC3864MPDE#TRPBF | LTC3864MPMSE#PBF | LTC3864MPMSE#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A | DC1722A,DC2434A |
Design Tools | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good | 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Power Good |
Тактовая частота, kHz | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 | 850 |
Frequency Adjust Range | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz | 50kHz - 850kHz |
Frequency Sync Range | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz | 75kHz - 750kHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
Isupply, мА | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Выходной ток, A | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Sense Resistor | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense |
Switch Current, A | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Vin Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vin Min, В | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
Vout Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vout Maximum | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin | Vin |
Vout Min, В | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
Vref Accuracy Over Temp, % | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
LTC3864EDE#PBF | LTC3864EDE#TRPBF | LTC3864EMSE#PBF | LTC3864EMSE#TRPBF | LTC3864HDE#PBF | LTC3864HDE#TRPBF | LTC3864HMSE#PBF | LTC3864HMSE#TRPBF | LTC3864IDE#PBF | LTC3864IDE#TRPBF | LTC3864IMSE#PBF | LTC3864IMSE#TRPBF | LTC3864MPDE#PBF | LTC3864MPDE#TRPBF | LTC3864MPMSE#PBF | LTC3864MPMSE#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Статьи
- 40µA IQ, P-Channel Step-Down Controller Operates from 60V to 3.5V VIN and Maintains High Efficiency at Light Loads &mdash LT JournalPDF, 2.7 Мб, Файл опубликован: 10 апр 2013Выписка из документа
Серия: LTC3864 (16)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | High Input Voltage Buck | External Power Switch Buck Controllers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
