Datasheet Linear Technology LTC3862 — Даташит
Серия | LTC3862 |
Multi-Phase Current Mode Step-Up DC/DC Controller
Datasheet LTC3862
PDF, 1.0 Мб, Версия: C, Файл закачен: 24 сен 2017, Страниц: 42
Купить LTC3862 на РадиоЛоцман.Цены — от 280 до 403 ₽ 44 предложений от 25 поставщиков Boost, SEPIC Regulator Positive Output Step-Up, Step-Up/Step-Down DC-DC Controller IC 24-QFN (5x5) | |||
LTC3862EFE#PBF Analog Devices | 280 ₽ | ||
LTC3862EFE#PBF Analog Devices | 284 ₽ | ||
LTC3862IUH#PBF Analog Devices | по запросу | ||
LTC3862 | по запросу |
Parameters / Models | LTC3862EFE#PBF | LTC3862EFE#TRPBF | LTC3862EGN#PBF | LTC3862EGN#TRPBF | LTC3862EUH#PBF | LTC3862EUH#TRPBF | LTC3862HFE#PBF | LTC3862HFE#TRPBF | LTC3862HGN#PBF | LTC3862HGN#TRPBF | LTC3862HUH#PBF | LTC3862HUH#TRPBF | LTC3862IFE#PBF | LTC3862IFE#TRPBF | LTC3862IGN#PBF | LTC3862IGN#TRPBF | LTC3862IUH#PBF | LTC3862IUH#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A | DC1286A-A |
Design Tools | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL | PolyPhase, External Synchronization, Resistor Set Frequency, PLL |
Тактовая частота, kHz | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 | 600 |
Frequency Adjust Range | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz | 75kHz to 500kHz |
Frequency Sync Range | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz | 50kHz to 650kHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 |
Isupply, мА | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
Max Phases | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 |
Monolithic | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Sense Resistor | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense | Rsense |
Switch Current, A | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic | Boost, Sepic |
Vin Max, В | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 |
Vin Min, В | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Vin Min Startup, В | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Vout Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vout Maximum | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher | 9V and higher |
Vout Min, В | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 | 1.223 |
Vswitch Max, В | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 |
LTC3862EFE#PBF | LTC3862EFE#TRPBF | LTC3862EGN#PBF | LTC3862EGN#TRPBF | LTC3862EUH#PBF | LTC3862EUH#TRPBF | LTC3862HFE#PBF | LTC3862HFE#TRPBF | LTC3862HGN#PBF | LTC3862HGN#TRPBF | LTC3862HUH#PBF | LTC3862HUH#TRPBF | LTC3862IFE#PBF | LTC3862IFE#TRPBF | LTC3862IGN#PBF | LTC3862IGN#TRPBF | LTC3862IUH#PBF | LTC3862IUH#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- 4-Phase Boost Converter Delivers 384W with no Heat Sink &mdash DN453PDF, 96 Кб, Файл опубликован: 23 сен 2008Выписка из документа
Статьи
- 2-Phase, Non-Synchronous Boost Controller Simplifies Design of High Voltage, High Current Supplies &mdash LT JournalPDF, 1.5 Мб, Файл опубликован: 1 янв 2009Выписка из документа
Серия: LTC3862 (18)
- Power Management > Switching Regulator > SEPIC Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
