Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Linear Technology LTC3851A-1 — Даташит
СерияLTC3851A-1
Synchronous Step-Down Switching Regulator Controller
Datasheet LTC3851A-1
PDF, 442 Кб, Язык: анг., Файл закачен: 23 сен 2017, Страниц: 30
Dual, 2-Phase Synchronous Step-Down DC/DC Controllers
LifeElectronics
LTC3851A-1
LTC3851A-1 : 4.5-14Vin 1.5Vout@15A
Электромеханические реле Hongfa – надежность и качество 19 января 2023
LTC3851AEMSE-1#PBFLTC3851AEMSE-1#TRPBFLTC3851AEUD-1#PBFLTC3851AEUD-1#TRPBFLTC3851AHMSE-1#PBFLTC3851AHMSE-1#TRPBFLTC3851AIMSE-1#PBFLTC3851AIMSE-1#TRPBFLTC3851AIUD-1#PBFLTC3851AIUD-1#TRPBFLTC3851AMPMSE-1#PBFLTC3851AMPMSE-1#TRPBF
N123456789101112
КорпусMS-16E
Габаритный чертеж корпуса
MS-16E
3x3 QFN-16
3x3 QFN-16
MS-16E
MS-16E
MS-16E
MS-16E
3x3 QFN-16
3x3 QFN-16
MS-16E
MS-16E
Код корпусаMSEMSEUDUDMSEMSEMSEMSEUDUDMSEMSE
Индекс корпуса05-08-166705-08-166705-08-169105-08-169105-08-166705-08-166705-08-166705-08-166705-08-169105-08-169105-08-166705-08-1667
Количество выводов161616161616161616161616
Parameters / ModelsLTC3851AEMSE-1#PBFLTC3851AEMSE-1#TRPBFLTC3851AEUD-1#PBFLTC3851AEUD-1#TRPBFLTC3851AHMSE-1#PBFLTC3851AHMSE-1#TRPBFLTC3851AIMSE-1#PBFLTC3851AIMSE-1#TRPBFLTC3851AIUD-1#PBFLTC3851AIUD-1#TRPBFLTC3851AMPMSE-1#PBFLTC3851AMPMSE-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-BDC1432A-B
Design ToolsLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD FileLTspice Model,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst ModeDCR Current Sense, Power Good, External Synchronization, Tracking, Burst Mode
Тактовая частота, kHz750750750750750750750750750750750750
Frequency Sync Range250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz250kHz - 750kHz
Integrated Inductorнетнетнетнетнетнетнетнетнетнетнетнет
Ishutdown, мкА252525252525252525252525
Isupply, мА111111111111
Max Phases111111111111
Monolithicнетнетнетнетнетнетнетнетнетнетнетнет
Количество выходов111111111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125
Выходной ток, A252525252525252525252525
Polyphaseнетнетнетнетнетнетнетнетнетнетнетнет
Sense ResistorRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCRRsense, DCR
Switch Current, A252525252525252525252525
Synchronousдададададададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В383838383838383838383838
Vin Min, В444444444444
Vout Max, В5.55.55.55.55.55.55.55.55.55.55.55.5
Vout Maximum0.80.80.80.80.80.80.80.80.80.80.80.8
Vout Min, В0.80.80.80.80.80.80.80.80.80.80.80.8
Vref Accuracy Over Temp, %111111111111
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Modeling and Loop Compensation Design of Switching Mode Power Supplies &mdash AN149
    PDF, 1.4 Мб, Файл опубликован: 23 мар 2015
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
На английском языке: Datasheet Linear Technology LTC3851A-1
