Datasheet Linear Technology LTC3829IFE#PBF — Даташит
Серия | LTC3829 |
Модель | LTC3829IFE#PBF |
3-Phase, Single Output Synchronous Step-Down DC/DC Controller with Diffamp
LTC3829 - 3-Phase, Single Output Synchronous Step-Down DC/DC Controller with Diffamp
PDF, 437 Кб, Версия: D, Файл закачен: 27 мар 2018
Купить LTC3829IFE#PBF на РадиоЛоцман.Цены — от 402 до 2 617 ₽ 31 предложений от 17 поставщиков IC: PMIC; преобразователь DC/DC; Uвх: 4,5÷38ВDC; Uвых: 0,6÷5ВDC | |||
LTC3829IFE#PBF Analog Devices | 402 ₽ | ||
LTC3829IFE#TRPBF Linear Technology | 443 ₽ | ||
LTC3829IFE#WPBF Linear Technology | 1 046 ₽ | ||
LTC3829IFE#PBF Analog Devices | от 2 162 ₽ |
Корпус | TSSOP-38 |
Код корпуса | FE |
Индекс корпуса | 05-08-1772 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC1530A,DC1675A |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Burst Mode, Differential Remote Sense, Phase Shedding, DCR Current Sense, Active Voltage Positioning, External Synchronization, Resistor Set Frequency, Nonlinear Control |
Тактовая частота | 770 kHz |
Frequency Adjust Range | 250kHz - 770kHz |
Frequency Sync Range | 250kHz - 770kHz |
Integrated Inductor | нет |
Ishutdown | 40 мкА |
Isupply | 4 мА |
Max Phases | 3, 6 |
Monolithic | нет |
Количество выходов | 1 |
Выходной ток | 90 A |
Polyphase | да |
Sense Resistor | Rsense, DCR |
Switch Current | 90 A |
Synchronous | да |
Topology | Buck |
Vin Max | 38 В |
Vin Min | 4.5 В |
Vout Max | 5 В |
Vout Maximum | 5V |
Vout Min | 0.6 В |
Vref Accuracy Over Temp | 0.75 % |
- A Closed-Loop, Wideband, 100A Active Load &mdash AN133PDF, 1.3 Мб, Файл опубликован: 12 окт 2011
Digital systems, particularly microprocessors, furnish transient loads in the 100A range that a voltage regulator must service. Ideally, regulator output is invariant during a load transient. In practice, some variation is encountered and becomes problematic if allowable operating voltage tolerances are exceeded. 100A load steps, characteristic of microprocessors, exacerbate this issue, necessitating testing the regulator and associated components under such transient loading conditions. To meet this need, a closed-loop, 500kHz bandwidth, linearly responding, 100A capacity active load is described in this document.Выписка из документа - Basic Concepts of Linear Regulator and Switching Mode Power Supplies &mdash AN140PDF, 715 Кб, Файл опубликован: 1 окт 2013Выписка из документа
Design Notes
- High Efficiency, High Density 3-Phase Supply Delivers 60A with Power Saving Stage Shedding, Active Voltage Positioning and Nonlinear Control for Superior Load Step Response &mdash DN489PDF, 100 Кб, Файл опубликован: 18 мар 2011Выписка из документа
Серия: LTC3829 (8)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC3829IFEPBF, LTC3829IFE PBF
