Datasheet Linear Technology LTC3784 — Даташит
Серия | LTC3784 |
60V PolyPhase Synchronous Boost Controller
LTC3784 - 60V PolyPhase Synchronous Boost Controller
PDF, 530 Кб, Версия: B, Файл закачен: 23 сен 2017
Купить LTC3784 на РадиоЛоцман.Цены — от 330 до 1 661 ₽ 24 предложений от 13 поставщиков Boost Regulator Positive Output Step-Up DC-DC Controller IC 28-QFN (4x5) | |||
LTC3784EGN#PBF Analog Devices | 330 ₽ | ||
LTC3784EUFD#TRPBF Analog Devices | от 334 ₽ | ||
LTC3784IUFD#PBF Analog Devices | 347 ₽ | ||
LTC3784HUFD#TRPBF Analog Devices | по запросу |
Parameters / Models | LTC3784EGN#PBF | LTC3784EGN#TRPBF | LTC3784EUFD#PBF | LTC3784EUFD#TRPBF | LTC3784HGN#PBF | LTC3784HGN#TRPBF | LTC3784HUFD#PBF | LTC3784HUFD#TRPBF | LTC3784IGN#PBF | LTC3784IGN#TRPBF | LTC3784IUFD#PBF | LTC3784IUFD#TRPBF | LTC3784MPGN#PBF | LTC3784MPGN#TRPBF | LTC3784MPUFD#PBF | LTC3784MPUFD#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A | DC2061A |
Design Tools | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File | LTspice File,LTpowerCAD File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | PolyPhase, 100% Duty Cycle, Burst Mode, Resistor Set Frequency, External Synchronization, Power Good |
Тактовая частота, kHz | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 | 900 |
Frequency Adjust Range | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz | 50kHz - 900kHz |
Frequency Sync Range | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz | 75kHz - 850kHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Isupply, мА | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 | 0.028 |
Max Phases | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 | 2, 3, 4, 6, 12 |
Monolithic | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Polyphase | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Sense Resistor | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR | Rsense, DCR |
Switch Current, A | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 |
Synchronous | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Topology | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost |
Topology 1 | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost | Boost |
Vin Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vin Min, В | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 |
Vin Min Startup, В | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
Vout Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vout Maximum | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V | 60V |
Vout Min, В | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Vswitch Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
LTC3784EGN#PBF | LTC3784EGN#TRPBF | LTC3784EUFD#PBF | LTC3784EUFD#TRPBF | LTC3784HGN#PBF | LTC3784HGN#TRPBF | LTC3784HUFD#PBF | LTC3784HUFD#TRPBF | LTC3784IGN#PBF | LTC3784IGN#TRPBF | LTC3784IUFD#PBF | LTC3784IUFD#TRPBF | LTC3784MPGN#PBF | LTC3784MPGN#TRPBF | LTC3784MPUFD#PBF | LTC3784MPUFD#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC3784 (16)
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > External Power Switch Boost
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
