Datasheet Linear Technology LTC3646EMSE-1#PBF — Даташит
Серия | LTC3646-1 |
Модель | LTC3646EMSE-1#PBF |
40V, 1A Synchronous Step-Down Converter
Datasheet LTC3646, LTC3646-1
PDF, 596 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 28
Купить LTC3646EMSE-1#PBF на РадиоЛоцман.Цены — от 250 до 1 265 ₽ 27 предложений от 15 поставщиков Buck Switching Regulator IC Positive Adjustable 0.6V 1 Output 1A 16-TFSOP (0.118, 3.00mm Width) Exposed Pad | |||
LTC3646EMSE-1#PBF Analog Devices | 250 ₽ | ||
LTC3646EMSE-1#TRPBF Linear Technology | 317 ₽ | ||
LTC3646EMSE-1#PBF Analog Devices | от 1 259 ₽ |
Корпус | MS-16E |
Код корпуса | MSE |
Индекс корпуса | 05-08-1667 |
Архитектура | Constant Frequency Controlled On-Time Current Mode |
Demo Boards | DC1731A-A,DC1731A-B,DC1820A-A,DC1820A-B |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Resistor Set Frequency, External Synchronization, Burst Mode, Power Good |
Тактовая частота | 3000 kHz |
Frequency Adjust Range | 200kHz - 3MHz |
Frequency Sync Range | 200kHz - 3MHz |
Integrated Inductor | нет |
Ishutdown | 8 мкА |
Isupply | 0.140 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 85 °C |
Выходной ток | 1 A |
Polyphase | нет |
Switch Current | 1.2 A |
Synchronous | да |
Topology | Buck |
Vin Max | 40 В |
Vin Min | 4 В |
Vout Max | 15 В |
Vout Maximum | 15V |
Vout Min | 0.6 В |
Vref Accuracy Over Temp | 1.5 % |
Серия: LTC3646-1 (12)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck | High Input Voltage Buck
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
LTC3646EMSE-1PBF, LTC3646EMSE-1 PBF, LTC3646EMSE1#PBF, LTC3646EMSE 1#PBF
