Datasheet Linear Technology LTC3615MPUF-1#TRPBF — Даташит
Серия | LTC3615 |
Модель | LTC3615MPUF-1#TRPBF |
Dual 4MHz, 3A Synchronous Step-Down DC/DC Converter
Datasheet LTC3615, LTC3615-1
PDF, 599 Кб, Язык: анг., Файл закачен: 22 сен 2017, Страниц: 32
Купить LTC3615MPUF-1#TRPBF на РадиоЛоцман.Цены — от 1 107 до 1 379 ₽ 9 предложений от 9 поставщиков Buck Switching Regulator IC Positive Adjustable 0.6V 2 Output 3A 24-WFQFN Exposed Pad | |||
LTC3615MPUF-1#TRPBF Analog Devices | 1 107 ₽ | ||
LTC3615MPUF-1#TRPBF Linear Technology | 1 379 ₽ | ||
LTC3615MPUF-1#TRPBF Linear Technology | по запросу |
Корпус | 4x4 QFN-24 |
Код корпуса | UF |
Индекс корпуса | 05-08-1697 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC1435A,DC1572A |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Burst Mode, Resistor Set Frequency, External Synchronization, Tracking, Anti-Phase Switching, DDR Mode, 100% Duty Cycle |
Тактовая частота | 4000 kHz |
Frequency Adjust Range | Up to 4MHz |
Frequency Sync Range | Up to 4MHz |
Integrated Inductor | нет |
Ishutdown | 0.1 мкА |
Isupply | 0.13 мА |
Max Phases | 2 |
Monolithic | да |
Количество выходов | 2 |
Рабочий диапазон температур | от -55 до 125 °C |
Выходной ток | 3 A |
Output Current 2 | 3 A |
Polyphase | да |
Switch Current | 6 A |
Switch Current 2 | 6 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Topology 2 | Buck |
Vin Max | 5.5 В |
Vin Min | 2.25 В |
Vout Max | 5.5 В |
Vout Maximum | Vin |
Vout Min | 0.6 В |
Vout Min 2 | 0.6 В |
Vswitch Max | 6 В |
Серия: LTC3615 (32)
- LTC3615EFE#PBF LTC3615EFE#TRPBF LTC3615EFE-1#PBF LTC3615EFE-1#TRPBF LTC3615EUF#PBF LTC3615EUF#TRPBF LTC3615EUF-1#PBF LTC3615EUF-1#TRPBF LTC3615HFE#PBF LTC3615HFE#TRPBF LTC3615HFE-1#PBF LTC3615HFE-1#TRPBF LTC3615HUF#PBF LTC3615HUF#TRPBF LTC3615HUF-1#PBF LTC3615HUF-1#TRPBF LTC3615IFE#PBF LTC3615IFE#TRPBF LTC3615IFE-1#PBF LTC3615IFE-1#TRPBF LTC3615IUF#PBF LTC3615IUF#TRPBF LTC3615IUF-1#PBF LTC3615IUF-1#TRPBF LTC3615MPFE#PBF LTC3615MPFE#TRPBF LTC3615MPFE-1#PBF LTC3615MPFE-1#TRPBF LTC3615MPUF#PBF LTC3615MPUF#TRPBF LTC3615MPUF-1#PBF LTC3615MPUF-1#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Micropower Buck Regulators | Internal Power Switch Buck
- Power Management > Switching Regulator > DDR Memory/Bus Termination
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
LTC3615MPUF-1TRPBF, LTC3615MPUF-1 TRPBF, LTC3615MPUF1#TRPBF, LTC3615MPUF 1#TRPBF
