Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Linear Technology LTC3417A-1 — Даташит
СерияLTC3417A-1
Dual Synchronous 1.5A/1A 4MHz Step-Down DC/DC Regulator with POR
Datasheet LTC3417A-1
PDF, 353 Кб, Язык: анг., Файл закачен: 21 сен 2017, Страниц: 20
AliExpress
Новинка LTC3417AIDHC-1 LTC3417AIDHC- 2 LTC3417AIDHC LTC3417A 3417A1 3417A2 DFN-16 IC
432 ₽
LTC3417A-2: 2.25-5.5Vin [email protected] 2.5Vout@1A
МосЧип
LTC3417A
LTC3417A-2
Электромеханические реле Hongfa – надежность и качество 19 января 2023
LTC3417AEDHC-1#PBFLTC3417AEDHC-1#TRPBFLTC3417AEFE-1#PBFLTC3417AEFE-1#TRPBFLTC3417AIDHC-1#TRPBFLTC3417AIFE-1#PBFLTC3417AIFE-1#TRPBF
N1234567
Корпус5x3 DFN-16
Габаритный чертеж корпуса
5x3 DFN-16
TSSOP-20
TSSOP-20
5x3 DFN-16
TSSOP-20
TSSOP-20
Код корпусаDHCDHCFEFEDHCFEFE
Индекс корпуса05-08-170605-08-170605-08-1663 (CA)05-08-1663 (CA)05-08-170605-08-1663 (CA)05-08-1663 (CA)
Количество выводов16162020162020
Parameters / ModelsLTC3417AEDHC-1#PBFLTC3417AEDHC-1#TRPBFLTC3417AEFE-1#PBFLTC3417AEFE-1#TRPBFLTC3417AIDHC-1#TRPBFLTC3417AIFE-1#PBFLTC3417AIFE-1#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Design ToolsLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD ModelLTspice Model,LTpowerCAD Model
Экспортный контрольнетнетнетнетнетнетнет
Основные особенностиAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty CycleAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty CycleAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty CycleAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty CycleAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty CycleAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty CycleAnti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty Cycle
Тактовая частота, kHz4000400040004000400040004000
Frequency Adjust Range600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz
Frequency Sync Range600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz600kHz to 4MHz
Integrated Inductorнетнетнетнетнетнетнет
Ishutdown, мкА0.010.010.010.010.010.010.01
Isupply, мА0.1250.1250.1250.1250.1250.1250.125
Max Phases2222222
Monolithicдадададададада
Количество выходов2222222
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A1.51.51.51.51.51.51.5
Output Current 2, A1111111
Polyphaseдадададададада
Switch Current, A2.52.52.52.52.52.52.5
Switch Current 2, A1.71.71.71.71.71.71.7
Synchronousдадададададада
TopologyBuckBuckBuckBuckBuckBuckBuck
Topology 1BuckBuckBuckBuckBuckBuckBuck
Topology 2BuckBuckBuckBuckBuckBuckBuck
Vin Max, В5.55.55.55.55.55.55.5
Vin Min, В2.252.252.252.252.252.252.25
Vout Max, В5.55.55.55.55.55.55.5
Vout MaximumVinVinVinVinVinVinVin
Vout Min, В0.80.80.80.80.80.80.8
Vout Min 2, В.8.8.8.8.8.8.8
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Internal Power Switch Buck
На английском языке: Datasheet Linear Technology LTC3417A-1
