Datasheet Linear Technology LTC3417AIFE-1#PBF — Даташит
Серия | LTC3417A-1 |
Модель | LTC3417AIFE-1#PBF |
Dual Synchronous 1.5A/1A 4MHz Step-Down DC/DC Regulator with POR
Datasheet LTC3417A-1
PDF, 353 Кб, Язык: анг., Файл закачен: 21 сен 2017, Страниц: 20
Купить LTC3417AIFE-1#PBF на РадиоЛоцман.Цены — от 313 до 1 848 ₽ 33 предложений от 17 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 2 Output 1A, 1.5A 20-TSSOP (0.173, 4.40mm Width) Exposed Pad | |||
LTC3417AIFE-1#PBF Analog Devices | 313 ₽ | ||
LTC3417AIFE-1#TRPBF Analog Devices | 395 ₽ | ||
LTC3417AIFE-1#PBF Analog Devices | от 1 580 ₽ | ||
LTC3417AIFE-1#PBF Analog Devices | по запросу |
Корпус | TSSOP-20 |
Код корпуса | FE |
Индекс корпуса | 05-08-1663 (CA) |
Архитектура | Constant Frequency Current Mode |
Design Tools | LTspice Model,LTpowerCAD Model |
Экспортный контроль | нет |
Основные особенности | Anti-Phase Switching, External Synchronization, Resistor Set Frequency, Power On Reset, 100% Duty Cycle |
Тактовая частота | 4000 kHz |
Frequency Adjust Range | 600kHz to 4MHz |
Frequency Sync Range | 600kHz to 4MHz |
Integrated Inductor | нет |
Ishutdown | 0.01 мкА |
Isupply | 0.125 мА |
Max Phases | 2 |
Monolithic | да |
Количество выходов | 2 |
Выходной ток | 1.5 A |
Output Current 2 | 1 A |
Polyphase | да |
Switch Current | 2.5 A |
Switch Current 2 | 1.7 A |
Synchronous | да |
Topology | Buck |
Topology 1 | Buck |
Topology 2 | Buck |
Vin Max | 5.5 В |
Vin Min | 2.25 В |
Vout Max | 5.5 В |
Vout Maximum | Vin |
Vout Min | 0.8 В |
Vout Min 2 | .8 В |
Серия: LTC3417A-1 (7)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Multiple Output Buck | Internal Power Switch Buck
LTC3417AIFE-1PBF, LTC3417AIFE-1 PBF, LTC3417AIFE1#PBF, LTC3417AIFE 1#PBF
